Old 11-14-2004, 06:18 PM
Mike1972 Mike1972 is offline
-94 GP 3100 misfire
It seems like my engine is misfiring.
Everything is fine at idle but under load itīs like it clogging and doesnīt respond to gas.
The thing is that on a dry day thereīs almost no problems, but when itīs raining or a lot of moisture in the air the car is almost impossible to drive.
Iīve checked the codes, the SES sometimes lights up but not at the same time as the misfiring, and it reads a code 13 and 44. (O2 circurit?)
Iīve changed sparkplugs and wires, no change.
Hope someone can help me!
Old 11-14-2004, 08:18 PM
dwalmop dwalmop is offline
Re: -94 GP 3100 misfire
The 13 is the o2 circuit, and 44 means simply, lean exhaust. Check for vacuum leaks. It's even possible you may have the dreaded lower intake manifold gasket leak. good luck.
