Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 11-14-2004, 07:11 PM
Talon93 Talon93 is offline
Max Boost
I was wondering what the max boost would be on a stock 93 Talon turbo 5 speed if I was to put a manual boost control valve on it, I mean leaving the bottom end ( crank, rods, and pistons stock), wouls 12 psi be to much, and what kind of power would I be building approx.
Old 11-14-2004, 07:29 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: Max Boost
first get a real boost guage because the stock one is almost worthless. once you get a real guage you can safely boost 14-15 once you've done all the free mods (remove intake silencer, remove bcs, dumptube mod, etc..) search here or vfaq.com for directions for the free mods
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 11-15-2004, 05:34 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Max Boost
I wuld rewire the stock fuel pump too (vfaq), 1g pump is a toilet.
On a PROPERLY SET UP 90-92 6 bolt 1g, over 30 psi is doable on the stock block/internals. On a 93, which has a 7bolt motor, I would be a little more careful, but 30 psi has also been done on those and over 500whp. The trick is getting the car properly set up
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 11-15-2004, 01:51 PM
FoRCedInDuKsionGsT FoRCedInDuKsionGsT is offline
Re: Re: Max Boost
Which is the dumptube mod? didn't know about that one...
Old 11-15-2004, 02:45 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: Max Boost
if your talking about your 14b turbo, getrid if the boost controll sylinoid, replace it with a $20 maunal boost controler, like said above get a boost gauge, and keep it under 18psi untell you change your fuel pump, rewire it.
DSM geek
Old 11-15-2004, 03:06 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
Re: Max Boost
but really get a boost gauge before you start screwing around with boost
