Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 11-14-2004, 03:46 PM
crzyCollegeKid crzyCollegeKid is offline
Question bottom-end buildup for turbo
after reading around, i don't think these questions have been asked before (at least not here), so here it goes:
all questions relate to a 5th gen h22
1) how low should the compression be lowered in comparison to boost?
a)is a thicker headgasket a plausible solution for this engine?
2) which internals should be upgraded for 15psi?
a) pistons? je or wiseco?
b) connecting rods? recommendations?
c) crankshaft? do they even make aftermarket for h22?
d) any at all?? cuz obviously you need sleeves if you replace the pistons...i think
3) who sells an engine rebuild kit for the h22 (bearings, gaskets, etc.)?
4) anyone here done a 15psi engine buildup?? if so, how much did it cost you?
any other practical things i probably missed.
if you haven't guessed it already, i wanna do an engine buildup and eventually boost around 15psi. these questions pertain to the bottom-end build up, any good advice for the top end?
Not-named-yet:
2011 Hyundai Sonata SE w/Sunroof and Nav in Iridescent Silver Blue Pearl
Claudia (traded-in):
2003 Mitsubishi Eclipse GTS: Pioneer Speakers All Around, Kenwood MP3 Deck, Clarion Equalizer, Boss 4ch. 800W amp, 2 Dual 12" subs with Dual 500W amp, XM Roady2
R.I.P. Jessica
1997 Honda Prelude: AEM CAI - Exedy Full Face Organic Clutch - XACT Streetlite 12.5lb flywheel - DC Sports Short Throw Adapter
Old 11-14-2004, 04:12 PM
Prelude707 Prelude707 is offline
Send a message via AIM to Prelude707
I'll try and answer what I know.
To run 15 psi a thicker headgasket alone won't lower your compression enough. 8.5 c/r is what I would go with. Remember it's generally agreed that less compression, more boost is better then more compression, less boost.
I've heard good things about both. Wiseco are quite a bit lighter, don't know if that's a good or bad thing. Heavier pistons would seem to be able to take more stress.
I'd go Crower.
I'm pretty sure your stock one will hold up fine.
I'd go with Golden Eagle sleeves.
2000 Honda Prelude
Mod list-
AEM CAI, AEM underdrive pullies, AEM FPR w/fuel rail, AEM brake pads, Apex'i N1 catback exhaust, Random Tech Hi-flow cat, Autometer fuel pressure & A/F ratio gauges, Apex'i VAFC(dyno tuned), ACT Xtreme pressure plate w/street disc and streetlite flywheel, Zex wet shot w/dual bottles and purge, Neuspeed front strut bar, VIS EVO CF hood, Honda Access door sills, NX bottle warmers, Lean Racing short shifter
Soon to come-
17" wheels, ES motor mount inserts
