Old 11-14-2004, 02:43 PM
sliko sliko is offline
97 s10 blazer surges and dies
i have a 1997 s10 blazer 4.3l v6 auto 4wd and about 4 days ago it started dying while driving down straight streets, then it would just start right up and go fine. suspected the fuel filter needed replaced so i did that and now it is worse than ever. it now acts like it is running out of gas, it will stall and start and go for just a little way and stall. the fuel tank is just above 1/8 on the gauge, could i possibly need to to fill the tank in order for the pump to prime as alot of fuel came out of the fuel lines when i disconnected the filter. any help would be greatly appreciated. thank you
Old 11-14-2004, 09:59 PM
barpat96's Avatar
barpat96 barpat96 is offline
When it dies does all the power on the dash go out?
Old 11-15-2004, 12:50 AM
jwbbx jwbbx is offline
Re: 97 s10 blazer surges and dies
My 97 Blazer just started doing this TODAY. Same symptoms as the first post, except last week I had a tune up AND they changed the fuel filter.
No idiot lights on the dash when I turn the key, can't move it out of PARK either.
Old 11-15-2004, 09:18 AM
no, the dash lights stay on and all electrical seems to work fine. when it dies it just seems as though it runs out of gas. i filled the tank and it still does this. hoping it is not the fuel pump.
Old 11-16-2004, 11:19 PM
barpat96's Avatar
the 97 Blazer has a bad Ignition switch that sometimes prevents power to certain things. for example mine would not crank or even die while going down the road. a friend of mine's would not get power to transmission componets. I don't know if this is even close to your problem but its worth looking into search this forum and you will see others who have had similar problems.
