Go Back   Automotive Forums Car Chat > Ford > Mustang > Performance
Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here.
Old 11-14-2004, 12:19 PM
brentmcq brentmcq is offline
Oil Change Frustration!
It was Friday night and I decided to change my oil around 10PM. Usually takes me about 15-20 minutes from start to finish. Everything was going according to plan until I fired up the engine and 5 quarts of brand new Royal Purple oil blasted onto my garage floor. I didn't forget to put in the plug or oil filter so my immediate thought was a defective oil filter. After spending a hour mopping up the oil and scrubbing the floor I pulled the filter back off for inspection. Everything looked fine until I realized the damn rubber gasket from the original filter was stuck to the engine block (something I always check except this time). Well I fixed that problem and 2 hours later I was finally done. I had to buy more oil the next day.
Cost of oil change:
10 quarts Royal Purple = $60
1 Oil Filter = $6
3 Beach Towels (to soak up oil) = $15
Total = $81
2000 GT 4.6L 5spd, BBK cold air, BBK 75mm TB, Bassani catted X-pipe, (no headers) FM catback, 390 gears, SCT chip, Steeda Pulleys, ported stock plenum, Comp Cam XE262AH. RWHP 260, Torque 282
Old 11-15-2004, 08:39 AM
burly94gt burly94gt is offline
Re: Oil Change Frustration!
shit happens...
God said RWD, and all the little torque lovers of the world said, AMEN!!
Old 11-15-2004, 02:20 PM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Expensive lesson learned.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 11-16-2004, 05:07 PM
eillob's Avatar
eillob eillob is offline
Been there done that with synthetic.
Ported Cobra Intake, Ported & polished Windsor Jr heads, K&N, Vortech s-trim, 90mm Lightining mass air meter, 70mm throttlebody,1.7 roller rockers, BBK Long tube headers, offroad H-pipe, Crane cam, main cap girdle, 40 series flowmaster, 3.73 gears, MSD ignition, CGS subframes, A9L PIH kit, SCT custom burned chip, 42lb injectors, 190lph fuel pump, T rex and fuel pressure regulator, AFCO racing radiator
(If it doesn't scare the Hell out of you it isn't fast enough)
Old 11-16-2004, 07:35 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
I got about 3 sentences in and knew it already! That sucks man, but its a lesson learned the hard way.
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
