Go Back   Automotive Forums Car Chat > Ford > Bronco
Old 11-14-2004, 09:28 AM
rickebling rickebling is offline
Unhappy replacing auto locking hubs with manual
Does anyone have instruction information on installing Warn manual locking front wheel hubs?
If you replace the hubs should the whel bearings be repacked?
Old 11-14-2004, 12:54 PM
Broncodriver Broncodriver is offline
Re: replacing auto locking hubs with manual
They should come with instructions with them. It doesnt seem that hard, just take one off and put the other on.
As far as the wheel bearings, yes repack them everytime you do something with the front (hubs, rotors, etc.).
If you cant get instructions, go to fullsizebronco.com someone on there will have them for sure. Or at least be able to walk you through it.
"If you can walk to the welfare office, then you can walk to work." -- Al Capone
Old 11-15-2004, 07:17 AM
Thanks, The reason I asked is because I had a set put on and a week later a rusty wheel bearing failed and ruined everything on the right spindle, invluding the spinlde.
Old 11-16-2004, 12:21 PM
goinbig goinbig is offline
Send a message via AIM to goinbig
Just replace the bearings at the same time. They are not expensive at all, and are worth it if your old ones are questionable at all.
They're easy to change too!!
Old 11-16-2004, 06:26 PM
Unhappy Re: Re: replacing auto locking hubs with manual
That is what I would think should be done especially by a shop that is speciallized in truck and off road equipment.
Old 11-18-2004, 09:45 PM
bigtimebroncoowner bigtimebroncoowner is offline
Didn't do it.
I changed the hubs out in my truck about 3 years ago. I did not repack anything and I have not had any problems 50,000 miles later.
Old 11-25-2004, 08:06 PM
Unhappy Re: Didn't do it.
I am glad to hear you have such good luck. I only made it about 1000 miles or less. It seems that repacking the bearing everytime the wheel is removed is the general advice I am getting.
