Go Back   Automotive Forums Car Chat > Ford > Probe
Old 11-13-2004, 11:29 PM
Timothy Moore Timothy Moore is offline
Unhappy Probe Fuse engine 2 blowing?
I have a 1990 Ford Probe 4 cyl. non-turbo with what started out to be a battery problem. The negative battery cable was loose, and I am assuming that the battery was arching. Which in turn I think had blown my fuel pump - I had replaced the pump and also the negative cable. Now when I start the car, it runs for about 5 seconds and kills immediately. The reason it kills is always the "engine 2" fuse in the fuse block inside the vehicle has blown. I can replace this fuse, but the same thing happens again. Any suggestions or ideas?
Old 11-19-2004, 02:31 PM
4dr92cavi4cyl's Avatar
4dr92cavi4cyl 4dr92cavi4cyl is offline
Re: Probe Fuse engine 2 blowing?
My guess is the battery may have fried something else, wires, relays, anything that's causing it to short out and blow the fuse.
Old 11-19-2004, 03:03 PM
any other suggestions?
I have traced the entire wiring harness, and the only concern I had found was one wire which goes into the fuel pump assembly. The wire had sections where the insulation was worn off - bare wires. I spliced a new piece of wire in the placeof the bad section, but I am still having the same problem as described earlier.
Also does anyone know how to test relays and and in-line fuses? Any help on this would be greatly appreciated. I then could continue to trouble shoot the wiring.
Thank you,
Tim
Old 11-28-2004, 12:03 AM
MAURICIO027 MAURICIO027 is offline
Re: Re: Probe Fuse engine 2 blowing?
THERE IS A TOOL IN THE MARKET IS CALL POWER PROBE.THIS TOOL LETS U TEST WIRES BY PUT IN POWER EACH ONE.THE TOOL HAS A BUILD IN FUSE THAT IS RESETABLE.THE IS ONLY SOLD BY SNAPON.
Old 11-28-2004, 04:21 AM
Thanks...
Thanks for the info, my brother is a Snap-On Dealer - I will have to ask him if I could get the tester from him.
Thanks again,
Tim
