Old 11-13-2004, 11:05 PM
eliasonb763 eliasonb763 is offline
Send a message via MSN to eliasonb763
fuel pump whines
I have noticed that on my 99 2500 crew cab, the fuel pump has started to whine VERY noticably. Has anyone else had this problem or am I just special?
Old 11-14-2004, 02:13 AM
Rbraczyk Rbraczyk is offline
Send a message via AIM to Rbraczyk
Re: fuel pump whines
Nah that happens. 97-99 seem to make high pitched noises that can be as loud as the exhaust.
Old 11-14-2004, 01:35 PM
does this mean Ill have to replace it soon? My pump went bad on my 95 and I personally replaced it, so it wont be that bad of a deal.
Old 11-15-2004, 01:05 AM
skipr skipr is offline
I changed mine at 38,000 on my 1998 Z71, bought a OEM pump module, and it whinned loud from day 1. I'm now at 88,000. Don't worry about it untill u are dead on the road.( I mean your truck, not you dead on the road).
Old 11-15-2004, 07:29 AM
sitdusa sitdusa is offline
How long has it been since you changed the fuel filter? Mine was whining pretty bad and after I changed the fuel filter it was quiet...
Old 11-15-2004, 09:05 PM
busta's Avatar
busta busta is offline
yip
dont panic ive seen these last the life of the truck with a wine and ive seen the die very early, this is acommon gm problem if it does die DONT put a factory fuel pump in go with aftermarket pump with adjustable regulator in case you up grade your injector's or other mod's down the road ,,,,,,, good luck
Old 11-16-2004, 06:34 AM
GM doesn't make things like they used to. I have the original fuel pump at 284k and I frequently run it below 1/4 tank..
