Old 11-13-2004, 09:39 PM
eplummer eplummer is offline
Question Help! Location of thermostat
Can anyone help me? I need to change the thermostat in my daughter's 1998 Grand Prix. When she's driving, the temp almost goes into the red zone, then it backs way down to almost nothing, all within a minute or two. This keeps happening the whole time she's driving. At the same time, when she tries to run the heater, when the car temp is higher (above 190 or so), the heater only blows cold air. I figure the thermostat is sticking and is causing both problems,but I'm not sure where it is to change it. Can anyone tell me where the thermostat is located? I appreciate any help.
Old 11-13-2004, 10:37 PM
Scatterpack94SE Scatterpack94SE is offline
Da.. what engine?
Old 11-14-2004, 12:16 AM
BIG-L's Avatar
BIG-L BIG-L is offline
It's at the end of the top radiator hose towards the motor CLICK HERE for instructions.
~Larry~
ClubGP Member 6530
Since 2001
Old 11-14-2004, 12:32 PM
kustomkid54's Avatar
kustomkid54 kustomkid54 is offline
Re: Help! Location of thermostat
I was always told, "follow your top radiator hose. It's at the end".
Old 11-26-2004, 04:42 PM
Redgrandprix Redgrandprix is offline
Help! Location of Thermostat
I have been experiencing exactly the same issue you described on your daughter's Grand Prix. I replaced the T-Stat and it got worse...I took it to a repair shop and they indicated the problem had to do with leaks in the Intake Manifold...they took it apart and replaced the upper and lower gaskets on the plenum...nothing has seemed to correct the problem....I would be very interested to know if anyone else has successfull corrected this problem....Thanks, Redgrandprix.
