Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora
Old 11-13-2004, 08:08 PM
miro1118 miro1118 is offline
valve cover gasket
I was driving with the vent on today and noticed a burning oil smell on my 96 gls 2.0. Opened the hood and saw that some oil was leaking around the valve cover. How hard is it to change the gasket. I already see that the plenum needs to be removed. Any one done this before? Anything I need to look out for?
Please help.
Thanks
Old 11-14-2004, 07:59 PM
boschmann boschmann is offline
Re: valve cover gasket
It's all pretty straightforward, just b carefull with the crankcase vent hoses, cap & pipe coming from the valve cover. They hard plastic usually get brittle & will break easily if pulled on & the rubber hose gets soft & will fall apart.
Old 11-14-2004, 09:37 PM
mattyvdubj3 mattyvdubj3 is offline
its actually pretty simple, just dont force anything and dont get messy around the cam.....when oil is leaking its not always the valve cover either..it can be that piece that is on the over that is kinda like an oval with 2 tubes coming out of it...if that is bad you get leaks...if thats the case get one from a junk yard and inspect it for any leakage, because ur gonna need the whole piece
Old 11-14-2004, 09:49 PM
Thanks to both of you ill check it out
