Go Back   Automotive Forums Car Chat > Buick > Regal
Old 11-13-2004, 09:00 PM
danielabeyta danielabeyta is offline
1983 regal 3.8 oil problem
When i turn on the car the oil/clutch light comes on. If the oil pressure is low does anyone know how much a oil pump is for one of these and how hard is it to put in. Also could it just be a crappy sensor???
Old 11-13-2004, 10:03 PM
public's Avatar
public public is offline
Re: 1983 regal 3.8 oil problem
This engine had some serious oil related problems back then.
Yes it could be a bad sensor.
The oil pump is an easy job as the pump is external-on the front of the engine. The pick up tube is very long. You must fill the pump with vasoline prior to installation. I have NEVER seen another engine where this "vasoline" was required. Good Luck.
Yes, I am retarded.
Old 11-14-2004, 01:17 AM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
Re: Re: 1983 regal 3.8 oil problem
all engines i know of require the oil pump to be primed with vasoline to prevent a dry startup.
this is out of a saturn FSM - http://www.saturnfans.com/photos/sho...p/photo/15857/
Old 12-15-2004, 03:04 AM
AZeline's Avatar
AZeline AZeline is offline
Can't you just put some gear oil in?
Old 12-15-2004, 06:24 PM
public's Avatar
We always just used a little axle grease. Not a solid plug of vasoline. But that is what the book said so that is what we did.
Yes, I am retarded.
