Old 11-13-2004, 02:55 PM
austin944 austin944 is offline
Interior Noise HELPP!!!!
I have this very weird and annoying noise that I cannot figure out what it is or where it is coming from. It only makes it when you go over bumps big or small. It sounds like the windshield is loose. I can't figure out where it is coming from. Checked the windshield and it is not loose. Checked a plastice trim and that is not it either. WHAT CAN IT BE????
Old 11-13-2004, 08:53 PM
deb0704us deb0704us is offline
Send a message via AIM to deb0704us Send a message via Yahoo to deb0704us
Re: Interior Noise HELPP!!!!
It could be the struts.
Old 11-14-2004, 02:52 PM
troy1 troy1 is offline
AF -Advisor
one of my sway bar bushings worked out
Old 11-15-2004, 09:56 AM
WRBsGTP WRBsGTP is offline
It might be coming from the ceiling. My GP was making noise from what I thought was the seatbelt panel (i.e. my post from last month), but it turned out to be coming from the ceiling directly above it.
Apparently, there are clips that hold the top of the ceiling to the roof, and those clips need to be tightened every-so-often if you go over a lot of bumps. I was told that the clips need to be tightened more often w/GP's that have a sunroof. You should press on the ceiling, and if you hear that irritating creaky noise, then you'll know that that's where it's coming from.
Good luck! I know how maddening those noises can be.
Old 11-15-2004, 12:06 PM
Thanks I'll Try it!!
