Go Back   Automotive Forums Car Chat > Automotive Art > Remote Control Cars
Remote Control Cars Questions, comments or discussions on the wonderful little vehicles.
Old 11-13-2004, 11:40 AM
NewyorkKopter's Avatar
NewyorkKopter NewyorkKopter is offline
Exclamation Desprate NEED OF ESC
Hey guys here are some pictures of my car's chassis, motor, msc, etc. I really need to buy a ESC badly. Can anybody please help me and tell me which ESC would be best for my car thats under $40.00. Thankss
Old 11-13-2004, 12:54 PM
gigglesnirt's Avatar
gigglesnirt gigglesnirt is offline
Send a message via AIM to gigglesnirt
Re: Desprate NEED OF ESC
HELL YEA TL01!!!!!
just go to your local hobby shop, they're help you out with what you need
Old 11-13-2004, 01:51 PM
Howielong's Avatar
Howielong Howielong is offline
Send a message via AIM to Howielong Send a message via MSN to Howielong Send a message via Yahoo to Howielong
A ESC under $40. Good luck really. Scale that up to maybe $65 can you could get a nice one.
Old 11-13-2004, 03:15 PM
lol thanks, alright lets make it $65.00 Which Forward and Reverse ESC's are good and will work with my car? Please I am so desprate for one. Thanks
Old 11-13-2004, 03:18 PM
exactly wut i said, just go to your local hobby shop. they'll take care of everything, and when i was in need once i picked up an esc for 50$ at my local shop, and it works fine
Old 11-13-2004, 03:22 PM
seriously. O man I gots to go to Willis Hobbies. Its like 15-20 min from my house. What kind of ESC did you buy for your car? You have a TL-01 also?
Old 11-14-2004, 04:59 PM
hey guyz u there??
anywayz one more thing.
CAN SOME ONE PLEASE EXPLAIN TO ME THIS MOTOR TURN LIMIT THING
what does it mean, and like which is better higher number or lower number. I have a 540 motor so how many turns is that?
Old 11-14-2004, 09:00 PM
aN4rK1's Avatar
aN4rK1 aN4rK1 is offline
What kinda motor do u have? the turn thing is this:
The higher the turn (27T): Lower Top speed, Higer torque, and better acceleration
Lower the turn limit (13T or sumthing like that, or any lower): Higer the top speed, lower torque, and slower acceleration.
So when ur buying a esc just make sure u check the motor limit, u can have to haver a lower motor limit, that way if u wanna get a new motor, a faster one, u can no problem, but lower turn limits = more expensive, and if u want a decent ESC for the price, get on ebay good luck
Old 11-15-2004, 12:23 PM
Thanks, so overall a lower motor turn limit ESC is better? lol I'll need the luck to get a nice one from Ebay. The motor in my car is a 540-22K motor, I forgot what brand. It supposedly goes around 30-40 mph . Also any recommendations for a forward/reverse ESC?????
Old 11-16-2004, 06:08 AM
ANY SUGGESTIONS????lol sorry, but seriously you guys have any reccomondations for an ESC that'll work with my car??
Old 11-16-2004, 11:55 AM
2000-redrider 2000-redrider is offline
Take a look at the Novak XRS (15t) and the Duratrax Intellispeed Mild-Modified (16t). Both around $50.
Old 11-19-2004, 01:10 PM
Feint Motion's Avatar
Feint Motion Feint Motion is offline
Novak Explorer 2 is perfect and only runs about 45-5o buks.
~Josh~
OldUser:IImportSupra
Do You Have a Car that Goez Sideways?
Old 11-21-2004, 04:06 PM
Hey, guys I finally ended up settling for the Futaba MC230CR ESC . Man it's AWESOME. I am so glad I got rid of that shitjob MSC . The ESC is so much better. And I get to disable/enable reverse, its crazy. I love it. Anyways thanks so much for ALL of ure help
Old 11-22-2004, 12:22 PM
Psman32@af Psman32@af is offline
Send a message via AIM to Psman32@af Send a message via Yahoo to Psman32@af
Futaba makes some nice stuff. god job on getting rid of that MSC and getting an ESC, there really is no reason to stay with an MSC unless you are totally broke. Anyway, your motor is a standard closed endbell motor, prob a mabuchi(sp?). nice, cheap effiecent motors. In which case it would be a 27 turn motor and wont spin very fast. To be much more precise then the person earlier, the number or turns a in a motor is the number of times that the wire inside the motor is turned around the motors armature. Therfore, the lower number of turns the motor, the less mass to spin so the motor (under no load) can spin to a higher rpm, and sometimes gets there faster.
Lower turn motors also require more power (thus higher ampdraw) and will drain a pack faster. To handle this higher amp draw, you need better construction and more expensive components. that is why cheaper ESC's cant handle lower turn motors, they cant handle the amp draw of those lower turn motors.
The whole better top speed and better acceleration statments made earlier are only true if teh gear ratios do not change. Changing the gear ratio though can change the whole story.
Machine wound motors, whether lower turn or higher turn motors will all be about the same price. Hand wound modified motors (27 turn motors are called stock motors, most others are modified motors) are more expensive, because they are woudn by hand (duh). They have tighter turns and a more ideal wire patteren then machine wound motors. They cost more to make, hence the higher price. they are also more powerful then machine wound motors.
i hope this helped, although i probally comfused you in teh process.
2005 Mercury Grand Marquis. 230 WHP 249 ft-lbs as measured by a mustang dyno.
Old 11-22-2004, 04:24 PM
lol thanks man. U know, its so much funner with a ESC than a MSC. My car used to like shake and jerk when going fast wit the MSC, now it can actually reach and stay. lol the diffrence is day and night
