Old 11-13-2004, 10:21 AM
adroit adroit is offline
window motor help :(
since the last week, my rear window on the driver side is messed up. Basically it goes down with the power window but it dosnt go back up, when I try to hit the up button, i hear the motor moving, but it dosnt touch the window, so the window just stays there....now the window goes up manually when I pull it with my hands, but when I am driving and go on bumps or potholes, the window will slide back down halfway....since winter started, its really a pain to drive. My friend said it might be a bad motor, but i hear the motor and thinkin the window is not sitting on the motor....anyone know how to change this or have a solution to this problem plz help.
thx
Old 11-15-2004, 11:56 AM
whataboutbob whataboutbob is offline
Send a message via AIM to whataboutbob
Re: window motor help :(
thx
Without knowing what year your Grand Am is, its hard to say what the problem would be. I know certain years of the Grand Ams that there was problems with the window regulators which is the mechanism for lowering and raising of the window.
www.gm-car-parts.com
Old 11-15-2004, 06:25 PM
i am sorry, forgot to post the year...its the 99 GT, if its the regulator, how much do they usually cost and are they easy to replace manually or do i need to take my car to a mechanic?
Old 11-16-2004, 07:50 AM
The window regulators now work from cables rather than the scissors style regulator and it often goes bad. GM recently lowered the price on the window regulators for the "N" bodies like your Grand Am from $300 to just over $100. I don't know how mechanically inclined you are but if you don't feel comfortable doing it then I would suggest a shop. I can get you the part for around $75 but I would feel much better if you did have it checked out to see if indeed it is the regulator before you get the part. You can email me direct at [email protected] or visit my website for online catalogs at www.gm-car-parts.com. Good Luck. Bob
Old 11-16-2004, 04:20 PM
ok thx, ill have it chked out now, thx a lot again.
Old 12-04-2004, 09:25 PM
Kevin Hastings Kevin Hastings is offline
I had that problem. Ran around with duct tape holding the window up. Did finally find the problem after replacing the motor twice. The mounting for the motor was rivited, and they were loose. This caused it to slip when pushing the window up. I drilled the old rivit out, and replaced it with a small screw, lock washer and nut. Havent' had any more problems.
Kevin
Old 12-26-2004, 06:58 PM
damienriley damienriley is offline
Send a message via Yahoo to damienriley
How 2 get the Door Paneling off
Hi. I have the same problem wih my Grand Am 2000. Does anyone know the way to pop the door paneling off? I've gotten it popped up with a cro bar all around the perimeter, but somethin's holdin' on in the middle there.
Any techs or weekend warriors out there know how to get the da&* thing off?
Thanx
Damien
Old 12-03-2005, 09:00 PM
kentucky will kentucky will is offline
Re: How 2 get the Door Paneling off
Thanx
Damien
Hey there, Ive just put a new regulator on my wife's car and I bought a freekin' book to do this. If it is a 4 door and the front drivers door there are three screws I removed from the middle. You are more than likley missing the screw under the window switch cover. Pry the cluster of buttons up and you'll find a screw there.that's the one that got me.
Willy
