Old 11-13-2004, 10:52 AM
Posey88cvic4dr's Avatar
Posey88cvic4dr Posey88cvic4dr is offline
Send a message via AIM to Posey88cvic4dr
Question Pistons/Rods/Cams for ZC?
Would I need to get those parts for the 88-89 teg? I know cams must be since the civic engine is SOHC, but I wasn't sure about the rest. Also, don't a few companies make ZC Headers?
4g4d4Life <--Link To My Car
TEAM CHOZEN
Old 11-13-2004, 10:15 PM
Re: Pistons/Rods/Cams for ZC?
Anybody....?
TEAM CHOZEN
Old 11-13-2004, 11:40 PM
94tegRS's Avatar
94tegRS 94tegRS is offline
Im "GUESSING" but id say headers for a 86-89 teg would work because they are basically the same engine. only thing is when you put them into your car they probably wont line right up to your stock exhaust, probably stick back too far so the flanges dont meet.
current
-84 datsun 720 4x4(2nd time)-93 accord-90 camry V6-90 warrior-94 300ex
history:
-01 R1-04 daytona 600-94 teg RS-95 teg LS
-91 teg RS-92 teg GSR-94 civic CX hatch (3 times)
-94 civic DX-96 civic HX-97 Accord LX-72 superbeetle
-74 beetle-84 silverado-66 c10-74 maverick-78 280z
-84 200sx-86 tercel wagon-95 mustang V6
Old 11-14-2004, 10:50 AM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
Re: Re: Pistons/Rods/Cams for ZC?
thats where Custom exhaust comes in
umm, i'm pretty sure the cams are for the 89 teg, rods u can use B18 rods, pistons u can get aftermarket for the motor if u bore it and such cuz they will hafta be bigger then. and any machine shop can cut the tops for ur valve clearance
Old 11-14-2004, 01:12 PM
so if I buy all these parts for an 88-89 teg, are they gonna work?
TEAM CHOZEN
Old 11-14-2004, 04:20 PM
travagliante's Avatar
travagliante travagliante is offline
You mean the cams because they are a DOHC!
Hmm any d-series header should work also!
Old 11-14-2004, 04:52 PM
94tegRS's Avatar
no, he asked if needed parts for the 1g teg, he then said he knew cams must be since the civic is SOHC. meaning he obviously couldnt get a cam for a SOHC, and he said camS plural so I knew that he knew his was DOHC.
current
history:
Old 11-14-2004, 10:44 PM
pissh, I know what I'm talking about....
but what parts do i need to buy?
TEAM CHOZEN
Old 11-14-2004, 11:28 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
Rods from any D16 engine work. Pistons also. Cams, im almost positive that they need to be zc specific cams. Crower Cams makes regrinds for I think it was $80 each. As for the header, just get one from an 88-91 civic and port match it with a die grinderor dremel, its not too hard at all.
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 11-15-2004, 12:29 AM
what's a regrind cam?
TEAM CHOZEN
Old 11-15-2004, 12:07 PM
94tegRS's Avatar
well, as far as I know they have 2 routes they go, one they weld on your cam and then remachine it to what specs you want and the other is no welding, they reduce the base circle diameter so that when valves are closed you can tighten the followers alot more and when the lob comes around there is more lift. they probably do also do a bit of machining to keep all the lobes symetric but not sure.
current
history:
