Old 11-13-2004, 08:43 AM
Roca46 Roca46 is offline
Motorbike exhaust pipe question
Hi!!
See this pic
How i make this little pieces??Which is her utility?
Old 11-13-2004, 09:47 AM
DukeMan's Avatar
DukeMan DukeMan is offline
You mean the springs? Well that´s easy, they are mounted to hold the exhaust system together. I´m using exhaust springs on my current project, a Ducati 916 (1/12 scale). In what scale are u building the bike/exhaust?
Since I´m a total geek, I´v measured everything on those springs and just give me the scale and I´ll give you the instructions. Here are mine temporary installed;
Regards, Fredrik
/Fredrik
Current Projects:
-´70 Camaro Z28 (Baldwin Motion hood wanted!!!)
-´32 Ford Roadster (on hold)
´69 Camaro thread
Old 11-14-2004, 12:14 PM
Hey!! thank you DukeMan!! I make in 1/12 scale how i make the springs??
PS: Amazing springs!!
Old 11-14-2004, 03:50 PM
DukeMan's Avatar
Ok, first you´ll need a small drill bit, a 0,3 mm will be fine and some really thin metall wire (I used soft silver wire) with an 0,2 mm diameter.
Put the drill bit in your pin vise or in your x-acto shaft (put some paper between the drill and the shaft) with the "wrong" side pointing out. Roll out some wire, grab an end with a tweezer or something and hold it close to the drill.
It´s a bit tricky indeed
Very carefully start wrapping the wire around the drill, when you´ve reached desired length, take a side-cutter and cut off the spring from the wire.
Yeah it´s a bit tricky in the beginning, but as soon as you get the hang of it there´s no problem.
Making the loop (on the spring) is also a bit difficult, but again, use the drill and carefully bend until you get a good shape.
Making the loop brackets is the easiest part, just use the drill and bend a lot of U-shaped parts (I promise you that you will lose some), cut and bend them according to the original 1:1 bracket.
I used CA (superglue) to attach the brackets. From here all you have to do is deciding where to put them, but mounting them will not be the easiest thing to do, but a pair of tweezers and a lot of patience will help you through.
Hope this will help you, good luck!
Regards, Fredrik
/Fredrik
Current Projects:
´69 Camaro thread
Old 11-15-2004, 12:05 AM
woooooow!!! 100000 thank's for this explanation i will put in practice soon
I had never imagined that towards this way
Okay! thank you very much!
Old 11-15-2004, 04:29 AM
sjelic's Avatar
sjelic sjelic is offline
Re: Motorbike exhaust pipe question
Great how to Fredrik, you saved me some writeing because I don't have photos. I only tend to "squize" the spring when it is still on the drill, that way it becomes even and if you need to stratch it affter it will come out even. So you don't need to take care when you roll it on the drill (just not to cross the coils) and then just press it on the pin vise so that all coils touch each other.
Edit: I forgot, they are used to join the exhaust pipes, so you can find them on every exhaust joint on the bike.
Sasa Jelic
SCALEMAKERS
Old 11-15-2004, 08:59 AM
Re: Re: Motorbike exhaust pipe question
Hep! thank you!
Old 11-15-2004, 05:22 PM
DukeMan's Avatar
Hey Roca46, no problem, I´m just happy to be able to help.
And sjelic, thanks for the nice comment, I really appreciate it.
Regards, Fredrik
/Fredrik
Current Projects:
´69 Camaro thread
Old 11-16-2004, 06:30 AM
rolin22 rolin22 is offline
Send a message via AIM to rolin22 Send a message via Yahoo to rolin22
Talking
another way to get springs is if you have a diecast lieng around pull them outta there or if you buy a modifier the usually come w/ extra springs( not sure if their the right sizr though)
