Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 11-13-2004, 12:22 AM
22ek9 22ek9 is offline
Help! oil leak
I have a 2000 hatch w/ JDM H22a, there is oil leaking, there is oil all over near the solenoid. Also it seems that the oil only leaks at higher rpm 4-5000+. Can anyone tell me what is up. The vtec also has been kicking in wierd, it pulses before it kicks in all the way but sometimes it doesn't kick in at all. What do i need to fix? It's really hard to tell where the oil is leaking from.
JDM H22A
DC HEADER, 5zigen rear section
skunk2 ecu
JDM silk road full coilovers
gs-r brakes F+R
Energy suspension bushings
Forged rear lower arms
more tie bars than you have fingers, upper, mid, and lower rear
etc...
bmw 5-series Xenon
and most the rest you can see....
Old 11-13-2004, 06:47 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
find the leak and replace whatever gasket/o ring there is and it will stop the leak
Team Lonely Drivers
Old 11-13-2004, 08:51 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: Help! oil leak
Sounds like the camshaft seal that is behind the VTEC solenoid is leaking. Replace it and then make sure your oil is full, if you are low on oil the VTEC solenoid may not engauge, remember that VTEC works off oil pressure, if the pressure is low then no VTEC.
