Keyless entry 2000 Blazer
I just purchase a 2000 4WD Blazer. Only one key came w/vehicle and NO fobs. It has keyless entry...no fob was included with the car. Dealer said previous owner didn't turn one in with vehicle. I have seen them for sale on ebay, however I don't know which ones to buy. What I need are the part numbers for a 2000 Chevy 4WD Blazer fob to purchase the correct ones.
With winter on the way and more than one driver for the vehicle the fobs would be a wonderful convience. Thanks in advance for help! |
I also had the same problem,Chevy wanted 60.00 for the fob and 30.00 to program it. I bought one from Ebay with program instructions for less than 25.00 and it works perfect.Email me and I will link you to the company I dealt with.. Dave
I have an extra fob but I need the instructions to program it. Can you help?
Regards, Heli |
Re: Keyless entry 2000 Blazer
1995 Factory Blazer Service Manual for sale, PM if interested. |
part# 15732805 to program.....and you can have up to 4 remotes. With the driver door closed, hold down the power unlock button on the door panel. Turn the ignition switch to the ON position. Turn the ignition switch to the OFF position. Turn the ignition switch to the ON position. Turn the ignition switch to the OFF position. Release the power unlock button on the door panel. The remote control door lock receiver will respond in the following manner in order to indicate that the receiver is in the programming mode: Locking the doors Unlocking the doors Important All extra transmitters must be programmed at this time. When a new transmitter is programmed, the old transmitters will be deactivated. Hold down the lock and unlock buttons on the transmitter until the remote control door lock receiver will respond in the following manner: Locking the doors. Unlocking the doors. Repeat step 7 for each additional transmitter. Turn the ignition switch to the ON position in order to exit the transmitter programming mode. |
I have a 1995 blazer. It is loaded. I bought it used, so I don't know if I have keyless entry or not. Does anybody know if I should have it already. Or give me some way of checking.Thanks.
It does.
Re: Re: Keyless entry 2000 Blazer
Because I own a 1995 Blazer Loaded and it has it.
No problem.
Thanks cobra1!
Will that P/N work on a 99 blazer?
Is that the standard FOB? |
this works but our bravada won't start. any ideas?
to program.....and you can have up to 4 remotes. With the driver door closed, hold down the power unlock button on the door panel. Turn the ignition switch to the ON position. Turn the ignition switch to the OFF position. Turn the ignition switch to the ON position. Turn the ignition switch to the OFF position. Release the power unlock button on the door panel. The remote control door lock receiver will respond in the following manner in order to indicate that the receiver is in the programming mode: Locking the doors Unlocking the doors Important All extra transmitters must be programmed at this time. When a new transmitter is programmed, the old transmitters will be deactivated. Hold down the lock and unlock buttons on the transmitter until the remote control door lock receiver will respond in the following manner: Locking the doors. Unlocking the doors. Repeat step 7 for each additional transmitter. Turn the ignition switch to the ON position in order to exit the transmitter programming mode.[/quote] |
