Go Back   Automotive Forums Car Chat > Toyota > MR2/MR-S
Old 11-12-2004, 09:49 PM
91 TRD 91 TRD is offline
Send a message via Yahoo to 91 TRD
3sgte conponents
Ok i have a 91' na, i am buying a hole/ half (wrecked to the extreme) 91'mr2 turbo with a perfect engine so i am taking the engine tranny and ecu, but the guy said to complete the swap i will need the turbo's cross brace and axles, is this true? or could i just use mine? or could u use a 5sgte tranny ( stock n/a's)tranny on a usdm 3sgte ? but i didnt know i would need thos parts to complete the car. I have not heard this before so i was not sure about that and are the turbo's brakes bigger compared to the n/a's?
Old 11-13-2004, 05:14 AM
JekylandHyde's Avatar
JekylandHyde JekylandHyde is offline
AF - Advisor
Re: 3sgte conponents
I would highly recommend using the turbo (3sgte) tranny and axles. They are beefier and the tranyn is geared for the turbo power band. The NA (5sfe) tranny will bolt up to the 3SGTE engine ... and you could drive that way, but it is far from ideal.
If I recall correctly, the rear brakes are identical.
The front brakes onthe turbo are dual piston and the NAs are single, but they are the same size.
Sponsorship: Amateur Motorsports <-- Get the book! - books are now available for shipment
Old 11-13-2004, 05:55 PM
ok that makes sence but how about the cross brase? do i need the turbo or can i use mine? And would it be hard to switch the front duel calipers over to my single calipers?
Old 11-13-2004, 06:49 PM
TRD2000's Avatar
TRD2000 TRD2000 is offline
The E153 Tranny From The Turbo Is Also Found In The V6 Camry.
Ratios Prob Different Though.
Who needs AWD? i feel inspired by the original 911 turbo, my car will have more rubber sqeezed in its ass than Annabelle Chong! and it will go down as one of the greatest rides in history!
