Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 11-12-2004, 06:53 PM
NaturalAspired NaturalAspired is offline
Where is the fusable link from the alternator on a 1996 neon?
I can't find it. The wire goes from the alternator to the computer and the computer to the fuse box then to the battery. The alternator isn't charging the battery and I've gone through 2 new alternators thinking they were bad, the last one the shop checked before I took it and it works..I'm thinking the link might be blown..The big wire on the alternator has power, so its hooked up. Would that still be the fusable link? my buddy said the computer is fried, but those are sooo expensive..Any help would be appreciated. by the way the battery was tested and its fine.
Old 11-14-2004, 04:35 PM
skatendestroy skatendestroy is offline
Send a message via AIM to skatendestroy
Re: Where is the fusable link from the alternator on a 1996 neon?
Hmmmm what i could say is go to a junk yard pick up a computer id check the wiring to and from the battery to alternator and check the grounds also check for the ground that runs from the batter connector to the metal thats in front of the radiator
if thats not connected it wont charge
also
