Go Back   Automotive Forums Car Chat > Buick > Skylark
Old 11-12-2004, 06:11 PM
lancesomers lancesomers is offline
Question A/C condensate leak
Can't stop. Anyone have idea, the a/c unit is leaking condensate from somewhere high along the inside firewall. Has been in shop for 3 weeks and thay don't know where to go other than removing entire dash and full a/c unit tp look for problem. This is a '94 Skylark 4-cylinder. No one seems to have any ideas, how about you guys!! Thanks
Old 11-20-2004, 09:50 PM
Puffnstuff's Avatar
Puffnstuff Puffnstuff is offline
Send a message via ICQ to Puffnstuff
Re: A/C condensate leak
When the car is running does the condensation from the ac drip onto the ground under the car? If not then the drain could be plugged.
06 Toyota Tundra Double Cab
Old 11-21-2004, 08:35 AM
What it actually Was
The factory-applied insulation-seal molding applied to thefirewall prior to installation of interior components dried out and caused the a/c handler to become loose from the firewall; vibration inceased the side of the bolt holes in the plastic case. The unit became loose, and the bottom pan, including the drain to the outside quit sealing to the upper case. When the a/c operated, some of the condensate went outside, but most of it went inside the vehicle. Dealer re-mounted unit and resealed it. BTW, they said they couldn't get a replacement liner, panel, whatever, to go on the firewall.
