Go Back   Automotive Forums Car Chat > Honda > Integra
Old 11-12-2004, 04:24 PM
BigBoyB's Avatar
BigBoyB BigBoyB is offline
Unhappy engine problems
when i am starting in first my engine starts to sputter like it wants to die or something, but once i am out of first it seems to run ok other than it is not shifting gears very smoothly. what could be the problem? transmition fluid? clutch?
96 gsr
lets roll[/font][/size]
Old 11-12-2004, 04:36 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: engine problems
Have you checked the clutch fluid? If it is low then the clutch will not fully dis-ingauge and can cause poor shifting and engine stalling/studdering. Is it hard to get it into 1st gear?
Old 11-12-2004, 09:39 PM
Technical_Automan Technical_Automan is offline
Banned
Re: engine problems
he's got a point about the clutch disengaging...if it's partially engaged it'll cause more load on the engine initially untill you get some speed going. I dont know if it's hydraulic or cable clutch, so if hydraulic: check the fluid level and check for leaks or air in the line. And if cable: adjust the cable and pedal freeplay. (that's only if that's your problem of course)
Old 11-12-2004, 09:47 PM
whtteg's Avatar
Re: engine problems
The 94+ integras are hydrolic and the pre 94's are cable. Just for future reference.
