Old 11-12-2004, 03:22 PM
elaxxx elaxxx is offline
ecu question
does anyone know how i can find out what OBD # number my ecu is in my car... i had a swap outta a 2000 civic si and my vtec isnt hooked up and i need to know what obd ecu i will need... thanks for the help
Tyrell
Old 11-12-2004, 07:55 PM
travagliante's Avatar
travagliante travagliante is offline
Re: ecu question
what ecu was put in? if its still your stock one its OBD0
Old 11-12-2004, 10:09 PM
thats the problem i have no idea... how can i find out and what one do i need to hook up my vtec. thanks
Old 11-12-2004, 10:31 PM
sivic02's Avatar
sivic02 sivic02 is offline
Re: ecu question
for the si i think its obd2 could be wrong....the ecu code is p2t, try searching a junk yard for one for cheap
Old 11-12-2004, 10:59 PM
Re: ecu question
Hey no way you will find a si ecu in a junkyard! Most likely they used an obd0 ecu, maybe a PR3, or a PW0. Check the ecu under the passangers floormat. Remove the metal cover with 4 10mm. bolts, then pull the ecu out. It should read something like 37820-_ _ _-.... then tell us the next 3 letters/digits after 37820! thats what we need to know.
And if they did use the si ecu (1999-2000) its OBD2B
Old 11-12-2004, 11:06 PM
sivic02's Avatar
Re: ecu question
The junkyards where im from are full of goodies that no one looks for. A friend got a full b16 swap for 500 bucks from a junkyard here. All the kids around here are all into the body kits and fart can exhausts, so the advantage for us who are into performance is we get all their wrecked stuff! Its great to have kids with parents who spend too much money on their kids in this town lol
Old 11-15-2004, 09:55 PM
i got the numbers off the ecu... first of all it had a marker mark on the top said b16... there where two sets of numbers... first set said 37820-pr3-9 01 and the second set says 411-104700 AB... is this the right ecu for vtec to work with it?
Thanks Tyrell
Old 11-16-2004, 02:06 PM
does anyone know cuz i am going to go to the shop today and i want to know because i dont want them telling me it is the wrong one then charging me for a new one when it is just the same one...
thanks for your help everyone
Tyrell
Old 11-16-2004, 02:39 PM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Re: ecu question
After using the search function.... use the "PR3" ECU that came with your B16 swap... (supposedly better than PW0 ecu. It will work with vtec for your B16 if you wire up your vtec solenoid to your ECU... but you'll have to ask somebody else on how to do that...
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 11-16-2004, 02:46 PM
sorry i got in a hurry and forgot to use the search function even though it is repeated over and over agian... but thanks that is all i needed i am going to have a shop hook up the wire's most likely i dont wanna mess anything up. i just didnt want them to tell me i had the wrong ecu and try to rip me off...
Thanks agian
Tyrell
Old 11-17-2004, 10:30 AM
4thgensvk 4thgensvk is offline
Send a message via AIM to 4thgensvk
Re: ecu question
what is it revving to
Old 11-17-2004, 01:16 PM
i ve have had the car up to about 8,000 rpms with no cut out or limiter kicking in... so do you think the ecu might be chipped?
