Old 11-12-2004, 12:07 PM
phantastic1 phantastic1 is offline
Exclamation 68 Camaro electrical problem
working on a 68 camaro and everytime i turn on power for the ignition or lights...the power gets grounded off somewhere. i've unhooked the junction behine the fuse panel and ran direct power from the battery to the positive (red) wire on the fuse panel (to eliminate any possibilities of a short under the hood). power is still getting ground off somewhere when i turn on the power. i have only isolated it to somewhere in the dash....and since i don't have a wiring diagram....i'm pretty much working in the dark. i was wondering if anyone has any idea what the problem may be. i'm was thinking it was my ignition switch...but power gets grounded off when i try to turn on the head lights.
Old 11-12-2004, 12:49 PM
korndogg's Avatar
korndogg korndogg is offline
Send a message via AIM to korndogg Send a message via MSN to korndogg Send a message via Yahoo to korndogg
Re: 68 Camaro electrical problem
did u check your headlight wires??
1968 Camaro 327
1999 Silverado 1500 Z71 LT
{o,o}
|)__)
O RLY?
http://www.cardomain.com/id/korndogg002
Old 11-12-2004, 02:35 PM
no i haven't...but does the ignition switch send power to the headlights when turned on even w/ the headlight switch off? i'll check it out and see.
Old 11-12-2004, 04:28 PM
korndogg's Avatar
sorry i meant the headlight switch wires. but i never really looked at my 68's electrical system so im not too sure.
1968 Camaro 327
{o,o}
|)__)
O RLY?
Old 11-14-2004, 09:00 AM
pjh pjh is offline
Question 68 electrical problem
I just experienced the same problem in my 67 camaro convertible.
Short was actually internal to head lite switch. replaced switch and problem went away.
I have also replaced the neutral safety switch as well as the turn signal switch.
good luck,
PJ
