Old 11-12-2004, 11:17 AM
deb0704us deb0704us is offline
Send a message via AIM to deb0704us Send a message via Yahoo to deb0704us
KYB vs Koni
Researching new struts. Guys here recommended KYB. Obviously KYB is less expensive than Koni. But what is this concern about the pogo effect all about? KYB tells you right up front it won't help pogo effect.
About KYB "If you're looking for something that's going to help with the pogo effect caused by aftermarket performance springs, these do not have the dampening characteristics to resolve that issue. They are great factory replacements to worn struts but the only thing that's going to help with the pogo effect caused by aftermarket performance springs is a performance strut with dampening characteristics matched to the performance springs. The only thing currently available for this is the Koni Sport Adjustable Strut package offered elsewhere in the suspensions category of the store."
About Koni...they are adjustable, but how? Knobs under the car? Isn't this inconvenient? Especially in winter?
Koni:"If you've upgraded your springs to Eibach or other aftermarket springs, you're all too familiar with the pogo effect. Koni serves sporting drivers with a carefully designed range of sport shock absorbers. This line focuses on exceptional road-holding and handling properties, combined with an acceptable level of comfort. Its characteristics include responsive steering, improved body control and limited body movements when braking and accelerating, all resulting in a direct feel and excellent wheel-road contact. Our Koni Sport dampers are externally adjustable by means of a knob, so they need not be disassembled from the car. The fine-tuning of the damping forces to personal driving style and to different driving conditions is therefore not more than a matter of seconds. The best of fine-tuning technology straight from the world of Formula 1 racing. The hunt for upgraded struts for your car is over. At this price there's no reason to look any further. "
Old 11-12-2004, 12:06 PM
dwalmop dwalmop is offline
Re: KYB vs Koni
Have you installed new springs? If not, go with the KYB's. KYB's are pretty much the best for stock setup. You won't get pogo effect by simply installing new KYB's with the stock springs.
Old 11-12-2004, 02:43 PM
BIG-L's Avatar
BIG-L BIG-L is offline
No pogo with the KYBs and stock springs and it only happens with aftermarket lowering springs & KYBs.
They adjust from the top.
Those must be the ones from PFYC and they are very spendy and not really worth it since GM also came out with a complete strut kit...What PFYC did was take a Ford Taurus strut housing and modified it so that it would fit our GPs with Koni .
If your looking for a great ride and a little lower stance id look into the GMPP (GM Performance Parts) konis part # 12498354
Adjustable Strut/Lowering Spring Suspension Kit
For use on 2000-2002 Chevrolet Monte Carlo; 2000-2002 Chevrolet Impala; 1997-2002 Pontiac Grand Prix. These lowering springs reduce the front ride height by .9 inches and rear ride height by .7 inches. Higher rate coil springs add to cornering ability and complement the adjustable struts. Struts accommodate compression/rebound adjustment easily from underhood (front) or in trunk (rear) with included adjuster knob. Adjustments can be made from a firm setting allowing maximum cornering to a soft setting approaching the ride quality of stock components. Technical Notes: Not Recommended for vehicles carrying high occupant or cargo loads or tow vehicles. Kit includes two front and two rear assembled strut assemblies. This kit includes the following items listed by part number quantity and description: P/N 11516382 - 4 - Nut, front suspension strut P/N 22152030 - 2 - Washer, front suspension strut P/N 22179011 - 2 - Mount assembly, front suspension strut P/N 22167000 - 2 - Retainer, front suspension strut mount P/N 00908554 - 2 - Bearing assembly, front suspension mount P/N 22166979 - 2 - Seat, front spring P/N 22181807 - 2 - Insulator, front upper spring P/N 22166978 - 4 - Shield, front suspension strut P/N 22166890 - 4 - Cup, rate front suspension shock P/N 22181835 - 2 - Insulator, front lower spring P/N 10283611 - 2 - Washer-rear suspension strut mount P/N 10445033 - 1 - Mount assembly rear suspension strut P/N 10445032 - 1 - Mount assembly rear suspension strut P/N 10286793 - 2 - Insulator, rear lower spring
They come ready to bolt in and nothing extra to buy and you only have to un-do 3 bolts up top and 2 bolts on the bottom.Ive had them on my car for almost 2 yrs and was well worth the money spent.They are $857.00 shipped from www.gmpartsdirect.com
~Larry~
ClubGP Member 6530
Since 2001
