Old 02-24-2002, 10:40 AM
alvinsiow alvinsiow is offline
96-99 civic EK with h22a
need some advice on swapping h22a in 96-99 civic ek?
pls post any links on owners if possible? wat major problems possible that can happened?
wat mounts,suspension,shift linkage,radiator being used.
is aircon, power steering available?
how fast is stock h22a civic in 1/4 mile?
Old 02-24-2002, 08:09 PM
rockerdude rockerdude is offline
good luck on doing that swap. you will need almost aftermarket everything to just to that engine in the car and make it drivable without the axles breaking. here's one problem you will definitely encounter. "UNDERSTEERING" of course there are more but too much to list.
Old 02-24-2002, 09:25 PM
white97ex's Avatar
white97ex white97ex is offline
Send a message via AIM to white97ex Send a message via Yahoo to white97ex
i was looking into dropping an H22a into my 97 ex coupe. after realizing i would spend pretty close to 10,000 for parts labor motor and custom fab to keep p/s and a/c and the rumored understeer problem. i realized you could drop in something like a b18b and turbo it for just about the same amound of cash. and keep a/c p/s and not worry about handling problems. another problem is that in civics the motor is tilted forward and in the 'ludes, the moror is tilted back a little
Old 02-24-2002, 09:40 PM
so which mounts to use? hasport or place racing's?
price at usd 649?
www.hasport.com
www.placeracing.com
