Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 11-12-2004, 09:55 AM
1996GMCJimmy 1996GMCJimmy is offline
Sensor 1, Bank 1.
Hello,
I recently had my 1996 GMC S-15 Jimmy checked out because of a SERVICE ENGIGE SOON light, it turned out the proble is the Snsor 1, Ban1 that needs replacement. I know its an O2 sensor that needs replacement, but can anybody let me know where this SENSOR 1, BANK 1 sensor is localted? Thanks a lot!
Old 11-12-2004, 05:59 PM
Jeremy-WI Jeremy-WI is offline
Re: Sensor 1, Bank 1.
Follow exhaust on the drivers side of the engine from the exhaust manifold back, it will be the first one.
In case you want to know Bank 2 sensor 1 is the closest to the engine on the passenger side
Bank 1 sensor 2 is the one between the y pipe and catalytic converter and bank 1 sensor 3 is the one between cat and muffler. This info is for a single cat exhaust which was pretty much standard on the 4.3 or 5.0
Old 11-12-2004, 07:21 PM
Jeremy-WI,
Thank you so much! Your input helps a lot, especially knowing where the rest of these sensor are also located.
Old 11-12-2004, 09:15 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
What did the code say?
Not all O2 sensor codes mean you have to replace the sensor.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 11-15-2004, 05:48 PM
Re: Re: Sensor 1, Bank 1.
Hello BlazerLT:
The code read as follows:
P0133
O2 Sensor CKT Slow Response (Bank 1, Sensor 1)
Thank you for your input!
Old 11-15-2004, 08:24 PM
BlazerLT's Avatar
AF -Advisor
Welp, in this case, yes, looks like the O2 sensor is lacking a lot.
Swap it out.
