Old 11-12-2004, 09:34 AM
frnkrizo frnkrizo is offline
Angry Dang Heater blower
Can anyone help? In the winter, and only in the winter . My heater blower has to be smacked under the hood everytime I start my Blazer to get it running. And like clock work it stops working as soon as I shut it off. I imagine this is a problem with the fan blowere itself. But where is it and how do I get it out and replace it . Thanks for your help.
Old 11-12-2004, 09:38 AM
Mikado14 Mikado14 is offline
Re: Dang Heater blower
If you look at the firewall on the passenger side of the vehicle you will see it in back of the wheel well. It has a purple wire going to it (usually). Four screws hold it in place, piece of cake to change. They are under $50 and most times come with the squirrel cage attached.
Old 11-12-2004, 09:39 AM
oops, forgot about the black ground wire attached to one of the mounting screws and it will ground on the firewall.
Old 11-12-2004, 09:53 AM
I can not see what it is you are talking about. I see a black and purple wired plug going into a black box that seems to encompass all of the parts in that area. I have A/C could that make a difference in finding and removing the fan blower. I have changed blowers before and they are like you mentioned stuck on the firewall with 1-3 screws but I can't even see where this one is. this black box I am referring to has lines and instructions that say for motor service cut here. Or tear line here. I think that motor may be inside that big mess and it does not look easy to get in to. Thanks again and wow that was fast reply.
Old 11-12-2004, 10:00 AM
You have a newer Blazer, don't you. I have never changed one of the newer ones. Better get a chilton's or haynes manual or maybe someone else will post that has done it. I have heard rumors to the effect that the heater box has to be cut but as I said, I havn't seen one yet.
Old 11-19-2004, 09:52 PM
siv siv is offline
Here is a great link, it appears that you have to do some cutting. Get your Dremmel out.
http://www.autozone.com/servlet/UiBr...3d8018be29.jsp
Old 11-20-2004, 03:19 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Nice link.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 11-21-2004, 05:01 PM
Fireplug Fireplug is offline
Yep you have to cut the black box. I used a gas powered pencil style solder iron with a point type tip and it mades a nice clean melt/cut or a very short hack saw blade but be carefull and take your time
Old 01-24-2005, 04:31 PM
Spencer0299 Spencer0299 is offline
i am getting ready to do the same job. Any other tips....also how did you get that bloack box piece to stay back on there....what compound did you use? This is the part that is scaring me the most is cutting the dang box. Anyone know exactly where to cut it at?
