Old 11-11-2004, 08:56 PM
az753 az753 is offline
Where are the Spark plugs
Hello,
I am in need of some guidance in finding the spark plugs in my 2001 Old Intruigue. Can someone please guide me as to where I might find them.
Need to replace spark plugs soon......
Old 11-11-2004, 09:38 PM
freakray freakray is offline
AF Modelrater
Re: Where are the Spark plugs
In the trunk
Welcome to AF, I will move this to the right area for you
AF User Guidelines
Old 11-12-2004, 12:15 PM
Ruley73's Avatar
Ruley73 Ruley73 is offline
Your 2001 Intrigue has the 3.5L DOHC V6 engine. This engine has a coil on plug ignition system and doesn't have spark plug wires. It has two sets of 3 coils, one for each cylinder bank. The spark plugs are under these coils and obviously are not visible. When you pop the hood you'll see what I'm talking about. You need to remove the acoustic cover and the hook on the back of it. Then you need to remove the coils. Each bank of coils has a plug going to it and is bolted to the valve cover with seven 10mm bolts. Next you'll need to remove the spark plug boots. They are somewhat fragile so be careful not to crack them. I just used my pinky or a pliers wrapped in a cloth (so it doesn't tear the boot) if it was stubborn. You will need a 10" extension on a ratchet with a 5/8" spark plug socket to remove the old/install the new plugs. This engine does have aluminum heads so be sure to use anti-seize on the spark plug threads. The specified spark plug gap is .050". Obviously, do the job when the engine is cold.
I highly recommend using only double platinum plugs to replace the old ones. I don't know the science behind it but other plugs simply don't perform the same in this engine. The O.E. Delco 41-980 plugs are the best. They are literally NGK stamped plugs in a Delco box The downside is that they are only available from a GM dealership and they might even have to order them (at least around here) and they cost about $9 each. Good double platinum alternatives that are much easier to obtain would be Autolite APP605 ~$4/ea, Champion 7013 ~$4.50/ea, and NGK 7740 ~$9/ ea. I don't recommend the Bosch Platinum plugs because a lot of the local auto technicians don't like them and won't use them.
I hope this helps.
Old 11-12-2004, 09:38 PM
Rolm's Avatar
Rolm Rolm is offline
On my 99 3.8 I installed the Champion 7013 I bought at walmart So far so good. I also had bad experince with Bosch plugs in my Mazda and I will never use the suckers again. If you can't get the orginal plugs then the next best thing are the Champion 7013 Dam these guys have been making plugs since the 1st engine was created. Why fool with sucess
Oh yaw make sure you change your plugs at 50,000 miles don't believe that crap from GM at 100,000 miles.
