Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 11-11-2004, 08:36 PM
djlacavera djlacavera is offline
Removing bed for fuel pump change
Hi does any one have an exact procedure for removing the bed on a 97 Sierra, for purposes of changing fuel pump?
Anything hidden I should know?
How many bolts, and there location?
Wiring connector locations?
The more details the better!
Also any advise on where to get a good but economical pump for this vehicle, would be appreciated!!!
Thanks much, Nick
Old 11-13-2004, 01:10 PM
70camaro 70camaro is offline
Re: Removing bed for fuel pump change
I am not familliar with the proceedure, but I am told there are 6 bolts, and one wire connector (probably near the cab). Sorry, that's all I know...
Old 11-21-2004, 07:56 AM
blabhern's Avatar
blabhern blabhern is offline
Send a message via AIM to blabhern
That's all it is, just make sure once all the bolts are out and you start moving the bed that you don't have any hidden wiring.
Old 11-24-2004, 12:18 PM
warren3537 warren3537 is offline
I had to replace the fuel pump and you have 8 bolts to remove, take out the tail lights, remove the tailgate, unclip the wiring harness from the back of the bed get two of your buddies and the three of you can lift the bed without taking off the rear bumper then you have an unrestricted access to replace the fuel pump.
Old 12-13-2004, 05:44 PM
bpnsd bpnsd is offline
Are you serious.I think I might try to drop the fuel tank.
Old 12-14-2004, 02:22 AM
BULLITTR6 BULLITTR6 is offline
Send a message via Yahoo to BULLITTR6
Haven't done it myself, but was told dropping the tank isn't that hard. A pump from GMC cost me $150. Lifetime warrenty when dealer installed. Auto Zone and O'rielly's have them for $80 - $100.
Personally, I would drop the tank down before lifting the bed. Good luck.
1991 F350 dually w/ 7.3 deezal
2008 Mustang GT
1993 Rodeo LS w/ 3.2 v6, 2wd (daughters)(Now totalled)
1991 Yamaha XT600
1993 Honda CR250R
Hard tellin', not knowin'
Old 12-14-2004, 09:23 AM
Jeremy-WI Jeremy-WI is offline
I didn't have to remove the taillights to move the bed on my 96, just had to disconnect the harness near the rear bumper and I think I had to unbolt a ground wire, and remove the bolts to the gas filler neck
Old 12-14-2004, 09:52 PM
a2cntryboy a2cntryboy is offline
Send a message via Yahoo to a2cntryboy
Cool Fuel pump
I had to replace the fuel pump in my 1997 GMC is was real easy to drop the tank all you need is a good floorjack and an empty tank.
Old 12-16-2004, 11:12 AM
Sivart Sivart is offline
Much easier to drop the tank in my opinion. Not a hard job at all.
Old 01-05-2005, 01:45 AM
ironran ironran is offline
what i did was disconnect the tank straps.drop the tank(it was empty)with a floor jack part ways down.Then i disconnected all lines and electrical plug to the pump.once the tank was on the ground, i slid it out from under the truck. I scraped the protective sealant stuff from the pump unit and then reversed the procedure.Be careful when attaching all lines, because if they are pinched or kinked alittle, then you will get a service engine light alarm.This would be a gas restriction.
Old 01-05-2005, 11:01 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
it depends on what the situation is...most of the time I pull the tank from underneath, but I have found that I can pull the bed off and swap pumps just as fast.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
