Go Back   Automotive Forums .com Car Chat > Chevrolet > Lumina
Old 11-11-2004, 08:15 PM   #1
cdurost
Send a message via Yahoo to cdurost
lumina
i have a 95 lumina apv i need to know if transmisson out of a 94 lumina car with a 3.1 will fit a 95 lumina apv 3800 both trans are 4t60-e trans thanks for your help
cdurost is offline   Reply With Quote
Old 11-12-2004, 09:36 PM   #2
richtazz
stupidity should hurt
richtazz's Avatar
Re: lumina
the trans bolt patterns are different between the two if I'm not mistaken. The 3.1 is a 60 degree V-6 and the 3800 is a 90 degree V-6. Therefore, I don't believe they are interchangeable.
richtazz is offline   Reply With Quote
Old 11-12-2004, 11:10 PM   #3
Kooterskkar
Send a message via AIM to Kooterskkar
If both tranny's are 4t60-e then it should work. It is possible on some transmissions to swap the bellhousing for one that will fit a different engine.
If you're going to get a used tranny you can check this place www.car-part.com
Kooterskkar is offline   Reply With Quote
Old 11-13-2004, 11:56 AM   #4
cadgear
cadgear's Avatar
Re: lumina
There were different models of 4t60e transmissions though, each slightly different. Here's a good variation reference (and bathroom reading)
http://60degreev6.com/hlperf/60V6%20...iles/4T60E.htm
cadgear is offline   Reply With Quote
