Old 11-11-2004, 06:52 PM
crizkeeth crizkeeth is offline
Heater fogging up windshield and making spots? WTF...
If its cold out and I turn on the heater to defrost the front windshield, it actually ends up fogging up the window MORE. Also, little "spots" show up on the windshield right over where the heater vents are. Is this a f'ed up heater core on my hands? Whats going on?
Its a '91 Accord LX
Old 11-11-2004, 09:17 PM
mpumas mpumas is offline
Re: Heater fogging up windshield and making spots? WTF...
Could be. You might smell the antifreeze. It does have a distinictive odor. Or you might have a leaking tail lights which is letting water into the trunk thereby increasing the inside humidity. Check your trunk under the carpet. If it is wet, you need to reseal the tail lights both on the trunk lid and the body.
Old 11-12-2004, 08:26 AM
AccordCodger AccordCodger is offline
Another possibility = the heater (core) drain is blocked - patially or completely.
Old 11-12-2004, 03:09 PM
94accordVTEC 94accordVTEC is offline
Send a message via AIM to 94accordVTEC
make sure the AC button is on as well as this will draw moisture out of the air.
Old 11-13-2004, 01:36 AM
DjHackStyle DjHackStyle is offline
Send a message via AIM to DjHackStyle Send a message via MSN to DjHackStyle
so your saying if its cold outside and i turn on the heater and choose the windshield button.....it should de-fog my windshield ?? IF THIS IS TRUE THEN MY SHYT HAS NEVER WORKED !!!..........ok what is the best way to DE-FOG the windshield because i just always put the WINDSHIELD button i put COLD AIR and choose A/C and it works alright but it gets cold in my car......wat u guys think ??
Old 11-13-2004, 10:31 AM
Turn the heater knob to heat with the airconditioner on. The airconditioner will remove humidity from the air and the heater will heat the air. The reason you get fog on the windshield is that the air in the car has moisture and the inside temperature is wamer then the temperature of the glass.
