Old 11-11-2004, 06:22 PM
sourcelx's Avatar
sourcelx sourcelx is offline
a good turbo?
I was looking at this turbo on ebay ,and i want to knopw if its a good deal.(for my 90 GS)Also will i need any other additional parts?
http://cgi.ebay.com/ebaymotors/ws/eB...category=33742
Old 11-11-2004, 07:25 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: a good turbo?
Couple things that stand out for me.
No mention of what compressor wheel is in the turbo, that I could see. Hard to make any guesses about performance.
The to4e/b housings dont come with a 2.5" outlet, its 2". The To4S has a 4" inlet and 2.5" outlet.
SS manifolds are not less prone to cracking than cast, they are more likely to crack. Not that they all do though. I've had good luck with my SFP manifold so far.
I think that was it. If this phsyically bolts to the head thats a good start. But there is still more work to do to turbo a NT car, and I'm sure its in the sticky at the top of the topics page.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 11-11-2004, 07:31 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
Re: a good turbo?
will that bolt on to a GS¿
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 11-11-2004, 08:41 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: a good turbo?
it wont bolt on to a 2g gs but it will bolt on to a 1g. the 1g nt is just a nt version of the 4g63
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 11-13-2004, 09:37 AM
sourcelx's Avatar
Re: a good turbo?
ok ,thanks for the info. I dont want to go and make a mistake and buy somthing i dont need.
