Go Back   Automotive Forums Car Chat > Dodge > Daytona
Old 11-11-2004, 04:55 PM
DodgeDaytonaV6 DodgeDaytonaV6 is offline
Daytona, No Start
Ok, I've had this problem for a long time now. After a good rain, the car refuses to start. I can hear the fuel pump engaging but there is no spark. Usually, after being left overnight, the car starts again. The cap, rotor and wires are fairly new and have been replaced since I noticed the problem. Any suggestions of what to try or look for? Thanks in advance...
1990 Dodge Daytona ES (Parts) | 1993 Dodge Daytona ES (DD/Project Car)
Doing/Done:
4 Wheel Disc Conversion (In progress)| 5 speed manual swap (In progress) | 52 mm Throttle Body | K&N Air Filter
Soon to come:
Underdrive Pulley System | Port & Polish Heads, Intake & Exhaust manifolds, and plenum | 0.040" Venolia Forged Pistons |
3" Catback exhaust (custom mandrel bent) | Custom exhaust manifold and crossover pipe | Garrett TO4E 57 trim | Walbro 255 lph Fuel Pump
Old 11-12-2004, 08:49 AM
rwood13 rwood13 is offline
Re: Daytona, No Start
coil, check wires leading to and from
Old 11-16-2004, 11:23 AM
slantsixness's Avatar
slantsixness slantsixness is offline
corroded connections to the ECM under the hood, bad pickup in the ditributor.
One of those ought to fix it.
Slantsixness
If I knew what I did to break it, I would've known not to do what I did.
www.classicwinnebago.com
