Ticking noise in exhaust
There is a ticking noise, sounds like it is coming from right behind the gauges inside the vehicle. I believe it is coming from the exhaust, possibly a small crack in the manifold? Anyone else have this prolbem? What can I do to fix it? Thanks
Re: Ticking noise in exhaust
Lemme guess, it only does it when it is cold out right?
1995 Factory Blazer Service Manual for sale, PM if interested. |
First of all, I would check out the air filter and make sure it is new and replaced.
ticking behind dash
i had a ticking like that , same place....it was the manafold gasket...
replaced it......gone :P hope that helps if thas your prob |
Sometimes that ticking could be cause by a restrictive exhaust.
Cat being restrictive, muffler on its way out etc....
Re: Re: Ticking noise in exhaust
also check under hood behind dash a black plastic shroud protecting several wire bundles mine was loose pushed it back into place and plastic push style pins regrabed firewall and noise gone the shroud was lose because of tracking down no start from ign switch
