Old 11-11-2004, 10:57 AM
TexasF355F1's Avatar
TexasF355F1 TexasF355F1 is offline
Send a message via AIM to TexasF355F1
Wireless Printing
Has anyone ever bought or used a wireless printer kit. I'd like to space my room out a little more and move my printer and its resting place to the otherside of the room. Hope someone can shed some light on this and let me know if its good or bad.
By the way my printer is an HP 1350 all-in-one
*Under Construction - New sig to debut*
Old 11-11-2004, 05:27 PM
Plastic_Fork's Avatar
Plastic_Fork Plastic_Fork is offline
Re: Wireless Printing
It's not that difficult. Just get a wireless print server, one or two ports. Just make sure it has whatever your printer uses - Centronics/DB25 for serial or USB connector if your printer is USB.
Also you'll need a wireless access point of some sort. If you have a network already and a router, just get an access point if it's not a wireless router. If you have neither, get the wireless router. You can still have your PC wired to the router, but the wireless print server can sit next to the printer.
The newer 802.11g wireless protocol is newer and will offer decent throughput although you can just get the 802.11b hardware since it may cost less and 802.11g isn't really necessary for a print server. The printer doesn't require all that much speed to query and process print jobs over wireless.
HP also makes their own print servers, but they're pretty expensive. Linksys makes great products for the cost and now that Cisco owns them, they're even better than before.
1995 Honda CRX del Sol VTEC
Manufactured: Suzuka, Japan
Production Sequence #1269
Team Del Sol member #1131
HondaVision: Team Sol Forum - Home of Team Del Sol
Old 12-28-2004, 05:34 PM
Raz_Kaz Raz_Kaz is offline
HP you say huh?
Well first thing you need is a print server, the HP one is a jetdirect and they are necessary if you want technical help from the 1-800 number. A gateway (usually the wireless router).
To tell you the truth I don't recommend the 1350 for a wireless setup, it's problem-galore. And also when you have a PSC or any multifunction on a wireless network, getting it to scan over that network is a 1:500 shot so good luck. I can help furthermore if you already have the printer, or I can recommend you a better one.
