Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 11-11-2004, 10:28 AM
opitica opitica is offline
Question Tire Width Help
My daytona needs 185/70-14 but I already have a set of 195/70-14's laying around. My question is, could I put the 195's on it and not worry about tire rub and hitting my shocks and struts. Is it safe?
Old 11-11-2004, 10:37 AM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
Re: Tire Width Help
its probably fine, it'll just make your speedo read a tiny bit too slow
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
Old 11-12-2004, 06:37 PM
Rufe Rufe is offline
The overall diameter is probably about a 1/2 inch greater, so you should lose about 1/4 inch of space in clearance. Most tires wear this much by the time they get close to the wear bars.
You will probably need about 1/3'rd of an inch behind the tire. This is probably fine as well. Check your current tires to be sure.
Note: This assumes the same model of tire is used.
Different brands, or model tires, could have a bit more variance.
