Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 11-11-2004, 09:49 AM
Cessnadriver Cessnadriver is offline
Unhappy No Spark on '97 Prelude
I've got a co-worker with a 97 lude that will not start.
Engine spins fine.
No spark, pluge have faint gasoline odor, though not wet.
Has been stalling on firtd startup of the day for a week.
Now it will not start at all.
Checked for spark at coil wire.
Ohmed out coil, within spec.
Getting 12 volts to proper pins on coil.
He swears this started when he first put 87 octane in it. I'm skeptical this is the problem.
Questions:
1. can the pgmfi relay cause this (no spark, i mean)
2. Is the ignition control module problematic on these cars, and does this sound like an ICM problem.
Thanks
Old 11-11-2004, 10:59 AM
94PreludeJDM's Avatar
94PreludeJDM 94PreludeJDM is offline
Re: No Spark on '97 Prelude
I don't know if this would be the problem, but Preludes aren't supposed to run on anything put Premium gas, Super + at minimum. Depending how hard he drove it, maybe that could have caused something. It's kind of a stretch, I don't know if that would cause the engine not to start.
Old 11-11-2004, 11:08 AM
Re: Re: No Spark on '97 Prelude
Thanks for the reply,
I doubt very seriously if he drove it hard at all.
He has since filled it with AMOCO Premium unleaded, but to no avail.
Old 11-11-2004, 05:35 PM
Gohan Ryu Gohan Ryu is offline
You're getting a spark from the coil but it's not getting to the plugs? Sounds like the distributor...
Old 11-11-2004, 05:37 PM
Crucified Ego Crucified Ego is offline
I don't think that's right.. I"m pretty sure Preludes are supposed to run on 'regular' 87/8 octane gas. Anything more actually combusts faster, a bad thing, and will only help if the car has a ping/tick problem.
-J
Old 11-11-2004, 05:51 PM
-J
Nope - all high compression vtec engines need the high octane premium - 91 octane minimum I think.
Bad gas still wouldn't cause the spark/ignition problem though.
Old 11-11-2004, 07:21 PM
Hmm. You're right. I should have done more searching before I posted that, my bad.
-J
Old 11-12-2004, 08:24 AM
Thumbs down
Well, we changed the min relay, no luck. Had to turn it over to a local shop as the owner really needs the car back in service quickly. I didn't want to start throwing electrical part$ at it that cannot be returned for refund. I'm thinking ICM or perhaps a TDC sensor. The fuel pump does cycle when the key goes to "on" position.
Old 11-12-2004, 10:48 AM
partyhardryan16 partyhardryan16 is offline
Not sure if this will help, but after 75k miles, 97' ludes are due for a free tune up from honda dealerships due to a recal in the plugs, wires, rotor, and distributor cap... not sure if this has anything to due with it though, but he should check to see if his lude has had this free tune up done already or not.
Old 11-12-2004, 12:22 PM
AcesHigh's Avatar
AcesHigh AcesHigh is offline
Prelude Guy
Send a message via AIM to AcesHigh
Check the firing order of the spark plug wires. This is the 75% cause of a car not starting up, when people take out their spark plugs from the dizzy and cylinder and then put them back in incorrect order.
Each of the connectors on the dizzy goes to a specific cylinder, and if this order is incorrect, the car will not start.
1993 Mazda Rx-7 Touring
Ricer Extraordinaire
Old 11-12-2004, 03:40 PM
Smile Problem Solved
Well, the problem ended up being a bad Ignition Control Module within the distributor.
The coil was getting 12 v but there was never ANY spark. I'm not sure I made that clear.
Changing out the main relay ws probably a good idea, according to the mech at the shop as they all fail eventually anyway.
Thanks to all who replied.
Old 11-13-2004, 09:34 AM
did you read what i said budd, about the free ignition tune up?
Old 11-13-2004, 09:21 PM
Yup.
he said it had already been done.
Thanks, though
