Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 11-11-2004, 09:36 AM
seabee-scum seabee-scum is offline
Question 91 C1500 Ignition Timing
Is there anyone out there that knows the exact timing spec. For a 91 GMC C1500 2wd 5 speed M/T with a 5.7L. And i don't believe it's 0 degrees. I've set it to that and it doesn't run great. And yes i do know about setting base timing and disconnecting the EST. If i advance it to around 8 Btdc runs awesome just ALOT! of valve ping. I rebuilt my engine and after all was done i realized my emission label under the hood is missing, sucks to be me. Does anyone have the same make?? Thanks.
Old 11-12-2004, 12:38 AM
2000CAYukon 2000CAYukon is offline
Re: 91 C1500 Ignition Timing
I have a 90 K1500 5.7 Automatic. The emissions sticker says Automatic and does not show a timing spec for a manual. I also have all of the Factory Service Manuals and they all say to look at the emissions sticker. A local dealer should be able to tell you the timing. I usually ask the parts guy if they can ask one of the mechanics to look it up.
Also, since you know it runs better at 8 then 0, back it off 2 degrees and see if the pinging stops. Repeat until the pinging goes away.
Did you put a new cam in the engine? If so, did you degree the cam?
//2000CAYukon
