Old 11-11-2004, 09:15 AM
BillyTheKid1969m BillyTheKid1969m is offline
Need Help With Charging Problem in 91 RS Camaro
I was hoping someone could help me. I recently got a 91 RS Camaro. It has high miles but runs good. The problem I have is after you run it for awhile, the battery charging gauge keeps going down and then it won't start. We got a new battery and the gauge still stayed the same and the car left me set again. I got a new alternator and still the gauge stays the same. It sets at about 8 and then the longer it runs, it keeps going down towards the red and then eventually dies or won't start when turned off. Cannot figure out what else it could be. Before I got the new battery, it left me set and when I got jumped, it would not turn over, that's why I thought it had to be the alternator. But, like I said, put that on and the gauge still don't go past the 8 mark and when I run it locally, it goes down slowly and when I turn it off, it won't start or starts slow. Everything is slow too, my power windows, wipers, etc. I'm hoping someone knows what this could be. Looking forward to reading your posts. Thanks a lot.
Old 11-11-2004, 01:26 PM
DaMoNe6969's Avatar
DaMoNe6969 DaMoNe6969 is offline
Re: Need Help With Charging Problem in 91 RS Camaro
check the wiring on the alt. Than check the fusable link between the starter and the battery..
check the battery make sure your terminals are clean and tight.. Follow the wiring down to the starter.. make sure the connections there are clean and tight..
1991 Camaro Z28
Old 11-12-2004, 11:52 AM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
if it wont even start with a jump, then its a wiring problem, it sounds like it could be a short to ground in the charging system, what i would suggest is to use a multimeter to check the resistance of all the wires in the circuits for an open, or short to ground.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 11-13-2004, 10:07 AM
NINÅ's Avatar
NINÅ NINÅ is offline
Originally Posted by BillyTheKid1969m
I was hoping someone could help me. I recently got a 91 RS Camaro. It has high miles but runs good. The problem I have is after you run it for awhile. . . . . .
It would have been helpful to know how long "a while" is.
Also does the batt. die when you're parked?
Anyway once you have determined you do not have a short to ground here's a secret to a faster pit stop: install a ONE WIRE type alternator. Since you have a new battery, and now you will have this impossible to mis-wire alternator you'll be good 2 go.
REFUSE TO LOSE
Old 01-08-2005, 09:26 PM
i need help i need help is offline
Send a message via MSN to i need help
i had the same thing a few years ago and when i but a new starter and it was fixed
