Old 11-11-2004, 08:03 AM
rubberman rubberman is offline
Stock foglights...
I have a burned out fog light. I want to replace with a brighter cleaner bulb but not go as far as replaceing the light housing or wiring. Just need a brighter bulb that will work in the OEM connector.
SYLVANIA/VALUCRAFT 9007BP/UPP $6.99
SYLVANIA/VALUCRAFT COOL BLUE HALOGEN 9007CBBP/UPP $14.99
SYLVANIA/VALUCRAFT LONG LIFE HALOGEN 9007LLBP/UPP $13.99
SYLVANIA/VALUCRAFT SILVER STAR HALOGEN 9007ST/UPP $19.99
1 PER PACKAGE
SYLVANIA/VALUCRAFT XTRA VISION HALOGEN 9007XV/UPP $9.99
SYLVANIA/VALUCRAFT SILVER STAR HALOGEN 9007ST/2UPP $49.99
How about the Xtra Vision bulbs? wonder if these come in pairs or sold single? thanks
2000 Grand Prix GT w/ gold package.
K&N CAI intake, U bend delete, ZZP PCM, Ractive oval exhaust tips, ZZP 3" downpipe
2004 Chevy Trailblazer EXT
Keep on Keeping on...
Old 11-11-2004, 06:04 PM
BIG-L's Avatar
BIG-L BIG-L is offline
If you are thinking about going with the Silverstars,Id go to your local Walmart and buy some Cyber white's, they are the same stock size and are much brighter and only cost 39.95 for a new pair of driving lights.
I just installed my NV-602W Pilot Cyber Whites from Walmart,and its the best 39 bucks I have ever spent! Finally decent lighting! Well anyways, the most difficult part about this mod was the brackets of course, since I needed a way to install these things securly. Once I figure it out, It was real easy to install. The picture below is real self explanitory, so for all you visual learners, here is a how to guide on how to customize the brackets.
Just cut the fog light bulb holder off cause there is no use for them anymore, we are just using the wires that go to the stock bulbs. Cut the plastic part of the wire so that you can see the actual copper wire, now the black wire on the fog light goes with the black wire, just slip it in little hole that the fog light has at the end of the wire, make it come out from the other side of the hole and fold it down and thats not going to go anywhere. Same thing with the white wire, but connect the white wire with the blue wire, put it through the little hole that the end of the foglight wire has and let it come through from the other side and fold it down.
Thanks for the Instructions from Amoroso
ClubGP Member 6530
Since 2001
Old 11-11-2004, 06:13 PM
94sportsedan 94sportsedan is offline
Re: Stock foglights...
Aren't 9007 the headlights we use not the fog lights??
Old 11-11-2004, 06:29 PM
BIG-L's Avatar
Yes they are,I didnt even notice,good eye!.Our fog lamp bulbs are Part # 880
~Larry~
ClubGP Member 6530
Since 2001
Old 11-11-2004, 08:24 PM
i seen some 880 silver stars. are they any better?
Old 11-12-2004, 10:15 AM
BIG-L's Avatar
Ive heard they arent really much britghter then stock,they just put out a whiter light,also I heard they burn out faster then the stock bulbs do.
~Larry~
ClubGP Member 6530
Since 2001
Old 11-16-2004, 01:01 PM
i found some 880ST at walmart. But damn they are $19 per bulbs. They have a blue tint to them.
Old 11-16-2004, 03:04 PM
SsHaDyGt SsHaDyGt is offline
i have the 893 bulbs from ebay euro dezigns just installed today if they dont hold up then i will switch to a whole new fog ligh setup they wiring cant be that bad
1998 silver gtp, GM performance Handling kit ,cold air intake, KYB struts ,HD supercharger coupler ,Gatorback belts ,U bend delete ,NGK TR6 plugs ,DHP PCM, Electric exhaust cutout - SOLD
98 White GTP, N* TB, 3.0 MPS pulley, SLP headers, 1.9 Rockers, 105# springs, ZZP PCM, Flowmasters, GM performance Handling kit, FWI, GMPP springs, U bend delete, SSIC, Ported LIM, Autolite plugs, ported SC, 12" brake upgrade with slotted cross-drilled rotors,
Old 11-16-2004, 10:46 PM
i found some bulbs on ebay that are 893's which are 37.5watts. will the extra 10w do damage to the foglight housing? they state that the 893 is also known as the 880 bulb.
Old 11-17-2004, 08:21 AM
BIG-L's Avatar
Ive seen others melt the lens cover....remember they are only plastic.
ClubGP Member 6530
Since 2001
Old 11-17-2004, 09:37 AM
WRBsGTP WRBsGTP is offline
they're plastic!? then how come mine cracked?
(and what's the maximum wattage you think our foglights can handle?)
Old 11-17-2004, 01:10 PM
GTPCatz GTPCatz is offline
Banned
Stock/New
Stock/New
New/Stock
New/Stock
New/Stock
New/Stock
Stock/New
Both New
Old 11-17-2004, 08:42 PM
BIG-L's Avatar
Our stock bulbs are 880 not H3....you must have aftermarket driving/fog lamps
ClubGP Member 6530
Since 2001
