Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 11-11-2004, 03:06 AM
marc_planas marc_planas is offline
Send a message via MSN to marc_planas
Clear Service oil Light
Hello, I need to Know if sombody knows how i can clear the Service Oil Light in a Pontiac Trans Sport 3.7 MY 1999.
Thank you.
Marcus
Old 11-13-2004, 01:35 PM
ciras3's Avatar
ciras3 ciras3 is offline
Re: Clear Service oil Light
With a lot of cars, you simply turn the key to the "run" without actually starting the car and step on the gas pedal 3-5 times. The light should blink a couple of times to tell you that it is cleared? Check your owners manual and see if it might tell you there.
"Just because the cat has her kittens in the oven doesn't make them biscuits."
Old 11-13-2004, 04:38 PM
LMP's Avatar
LMP LMP is offline
WOW...Funny..I did not know that.....On what type of cars were you able to test that! I did not have that problem anytime, but if that is the way to clear it, I would not have known !!! I'll put that in my "don't forget" list....
Old 11-13-2004, 07:25 PM
dwalmop dwalmop is offline
LOTS of GM's do it that way
Old 11-13-2004, 07:45 PM
ciras3's Avatar
I have to do that on my 97 Chevy Lumina. When you change the oil, you need to reset the computer to tell it that you changed the oil. Otherwise, after 8000 miles or so, the "service/change oil soon" light will come on to tell you it's time to change your oil.
Old 11-14-2004, 02:53 AM
LMP's Avatar
LMP LMP is offline
..WOuld I be right to think that this applies only to OBD2 cars...., that is post 95 (+/-). ?
Old 11-14-2004, 10:10 AM
ciras3's Avatar
That's probably a safe guess. I've owned a couple of OBD I GM's and none of them had that feature. My OBD II GM does have it.
Old 11-15-2004, 02:35 PM
marty824 marty824 is offline
Would this be the "OIL LEVEL" light. This light started to come on after my first oil change. There is no mention of this procedure in the manual. Could this be another thing GM kept to themselves?
Old 11-16-2004, 03:01 AM
Thank you Ciras3 its works perfectly.
Thank you very much from spain
Marcus
Old 11-16-2004, 02:24 PM
ciras3's Avatar
Re: Re: Clear Service oil Light
You're welcome ... I'm glad that you were able to get that trick to work for you.
