Old 11-11-2004, 12:50 AM
flaurora flaurora is offline
Send a message via MSN to flaurora Send a message via Yahoo to flaurora
Air conditioning vacum line
I have a 96 S-10 blazer 4.3. My air conditioning is only blowing out of the defroster and floor. I know that it is the vacum line is off so the switch isn't working. Does any one with a manual know where the thing hooks up I can't find it. I have been under the hood for an hour and can't find it. I suppose its on the firewall behind the engine because of the way its routed but I can't find where it connects
If it won't fit get a bigger hammer
Old 11-11-2004, 01:47 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Air conditioning vacum line
It connects to the vacuum ball near the driver's side firewall corner.
The switch problem will be in the dash.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 11-11-2004, 12:26 PM
Rick Norwood's Avatar
Rick Norwood Rick Norwood is offline
Big Tall Dumb Ass
Right-on! Check the Black vacuum ball.
Old 11-12-2004, 11:40 AM
DaveLance's Avatar
DaveLance DaveLance is offline
Unfortunately, it may not be that easy. I had the same problem and it turned out to be where the vacuum hose came through the firewall under the drivers side dash. It comes through as a rubber hose and attaches to a hard plastic hose. Where it goes before ending up at the control switch I couldn't begin to tell you. If you remove the panel under the drivers side dash and (with the vehicle running), listen for a hissing sound. It should be easy to hear. The hard plastic hose is in a wire bundle, so it's hard to get at. You have to feel for it and put the rubber hose back without being able to see it. One good thing is that after I replaced it, it hasn't come off since.
Old 11-12-2004, 01:54 PM
Its still connected to the vacum ball its the other end thats off....Sorry should have clarified that ....
Old 05-09-2005, 06:53 PM
twright5 twright5 is offline
I have the same problem. The hose is connected to the bal on the hood, but the other end that funs along the firewall is not connected. Were you able to find where to hook it up? Please reply if you have.
Thanks!
Old 05-12-2005, 12:35 AM
BlazerLT's Avatar
AF -Advisor
Re: Re: Air conditioning vacum line
Thanks!
It hooks to a slip fitting on the back of the intake.
There will be a nipple you will have to slide the hose onto.
It is to the left of the cap and rotor.
