Old 11-10-2004, 11:58 PM
stervv stervv is offline
92' Civic next step
I have a 92' civic with intake, exhaust, but not catback, strut bars, spoiler, and was wondering what to do next...i don't have alot of money and i was wondering what cheap next step would give me some extra Hp...i was thinking headers...or a catback...which would give more Hp and how much is a catback? many questions...thanks for any input...
Old 11-11-2004, 12:47 AM
Miataracer's Avatar
Miataracer Miataracer is offline
Send a message via AIM to Miataracer Send a message via Yahoo to Miataracer
Re: 92' Civic next step
ditch the fart can, replace it with a nice high quality performance cat back that is quiet. get a header
LS1 RX-7 Zoom Zoom
Old 11-11-2004, 12:48 AM
Miataracer's Avatar
dont expect a lot of power, you will get some but not much.
LS1 RX-7 Zoom Zoom
Old 11-11-2004, 04:15 AM
eckoman_pdx's Avatar
eckoman_pdx eckoman_pdx is offline
Honda God
Send a message via AIM to eckoman_pdx Send a message via Yahoo to eckoman_pdx
You may look into header unless you plan forced induction later on. If thats the case it's a waste of money IMO, as headers are not cheap and you will just be ditching it at that point anyway. As for a cat-back, you can get a decent qaulity ( and not oversized) universal muffler. Then take it too a muffler shop and have them run 2 1/4" custom piping. You can tune and deepen the exhaust note using a resonator. This will also quiet the exhuast down quite a bit, and a resonator helps deepen the tone somewhat and avoid the annoying high pitch squel assoisacted with fart cans.
A universal muffler, 18" resonator and 2 1/4" custom cat-back piping shouldn't run more than $290-$340 dollars total: parts, installed and done. You also may consider a street legel high flow cat. Random Technolgy makes a very good street legel High flow cat. If you need a new cat anyway, this is a very good way to go. You can get one for around $219 if you call them up and have them give you the number to a few their biggest distributors (you can usually cut you a good deal). They are really easy to install...unbolt and rebolt. A good time to put it in is when your having the cat-back exhaust work done (and the header installed if you opt for it). You can cut down on labor cost that way. However, the cat is VERY easy to install and it' pretty self explanitory once you look at it and the one under the car. Unbolt and re-bolt. It's pretty simple, even if you've never done anything of the sort before.
It's just that easy folks... mind the forum guidelines and we're cool.
Empty Pockets Racing Member #6
EPR Member 4 Life
Old 11-11-2004, 03:02 PM
95dxcivic's Avatar
95dxcivic 95dxcivic is offline
I have an exhaust, but it's not cat-back, it has a nice deep tone. I checked it out and the larger piping starts a little before my rear wheel. It's tone is not even close to a fart can.
I think that you should save your money for a better engine, a b-series if you want but they are more expensive, a v-tec d-series would be better if you dont have alot of money and it will definately be better than your 100HP d15b7. It will cost a few hundred dollars more than the custom exhaust and the hi flow cat but it will definately give you more power than the exhaust and cat.
lowered on photoshop(its not that low, its not lowered at all!)
Empty Pockets Racing Member #4
Old 11-11-2004, 03:20 PM
Honda God
A custom 2 1/4" cat-back exhasut is going to be cheaper than buying a pre-made set-up and he can then have the sound tuned to his likly, etc...old school style using resonators.
As for a motor swap, whether he's running a D16Z6 or a B-series motor, the car could use a better breathing exhaust. 92-95 civics come with a very small 1 3/4" piping. If he does a custom 2 1/4" cat back exhaust and high flow cat, it'll work for him now and for a future D16Z6 or B16A, etc swap. If he swaps in a B-series he'll want to do exhaust, either a custom cat-back or a pre-made one) for sure. 1 3/4" is too restrictive for a b-series. While you're at the exhaust, I've always felt it's best to do the street legel high flow cat right then, kill 2 birds with one stone. The cat and exhaust will work for him now and after a swap. If he wants to swap in an B-series, he will want the exhaust done soon thereafter, as 1 3/4" piping just won't do. For the most part, B-series cars came with 2" piping stock, so you at least want that. Since the exhaust is getting re-done anyway at that point, might as wel go to what is considered optimal, 2 1/4" piping.
EPR Member 4 Life
Old 11-11-2004, 03:53 PM
Ace$nyper's Avatar
Ace$nyper Ace$nyper is offline
Banned
Send a message via AIM to Ace$nyper Send a message via MSN to Ace$nyper Send a message via Yahoo to Ace$nyper
finish your exhaust sell your wing are you planning swap or boost?
Old 11-11-2004, 04:02 PM
i was planning on headers right now and i like my wing...thanks for all the ideas..just curious what a swap would cost for a b series...installler?...thanks
Old 11-11-2004, 04:24 PM
Honda God
Re: Re: 92' Civic next step
First off what motor do you want to swap? B16A, B16B, B18B1, B18C1, B18C5?
If you seriously want to swap don't waste $$ on a header. You won't be able to use it on your b-series motor after the swap, so it will just go to waste. Headers are motor specific. So a Header for a D16Z6 for example will NOT work on a B16A, GSR LS, etc. The means that when you swap, the header goes to waste.
If you want to swap, your are FAR better saving that $$ and putting it towards a swap or putting it into something like cat-back exhuast/piping/hi-flow cat, which you can use with this or a swapped b-motor.
EPR Member 4 Life
Old 11-11-2004, 11:48 PM
how are DC-S headers b/c i find them on ebay for $100 are they a good brand b/c they ar alot cheaper than all the other brands....thanks
Old 11-11-2004, 11:51 PM
Miataracer's Avatar
give us a link... if they are new and selling for only about $100 they are probably knock offs or something
LS1 RX-7 Zoom Zoom
Old 11-12-2004, 12:32 AM
its on ebay the link is http://cgi.ebay.com/ebaymotors/ws/eB...category=33631
Old 11-12-2004, 12:54 AM
Miataracer's Avatar
I would have to say stay away from that.
Problem #1. Its a knock off.
#2 Sellers positive feedback is kind of low
#3 The feedback is hiden. There are a ton of negative feedback comments and you can't see what they are because the seller hid them. They probably say things like 'it didn't fit' or 'it rusted out in a week' 'it cracked' etc.
#4 Shipping costs as much as the actual header??
http://cgi.ebay.com/ebaymotors/ws/eB...933543563&rd=1
i would go with something like that for about 30 bucks more any day. 100% positive feedback as well
plus i have actually heard of Holley
LS1 RX-7 Zoom Zoom
Old 11-12-2004, 01:34 AM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
lol DC-S, how much you want to bet the S standards for style. You get what you pay for remember that.
Empty Pockets Racing Member #1
Old 11-12-2004, 06:03 PM
thansk for the advice ...i will stay away from those and thansk for the link on the other header...how hard are they to install yourself and i've heard of these home made electric superchargers...how are they?...thanks
