Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 11-10-2004, 11:21 PM
supertec7622 supertec7622 is offline
New Z owner: slight hesitation on take off
Sweet board.. I just bought a 1990 N/A, At, Z.. Best car I have ever driven. I have a slight hesitation on take off.. Guy I bought it from thinks it just needs a tune up.. It runs awesome except for when you touch the gas a litle bit, it seems as though it wants to stall for a second.. Any help you guys can give would be great.. What should I expect to pay for a good tune up?? Thanks new Z fanatic
Old 11-10-2004, 11:54 PM
Karen512's Avatar
Karen512 Karen512 is offline
Send a message via AIM to Karen512 Send a message via Yahoo to Karen512
Re: New Z owner: slight hesitation on take off
fuel filter might need changing
2004 SRT-4
1998 GMC 2500
1996 Eagle Talon TSi AWD Turbo
1993 Eagle Talon TSi AWD Turbo
1985 Nissan 300ZX Turbo
1990 Nissan 300ZX Twin Turbo
Past Z Cars Crew
Old 11-11-2004, 12:07 AM
MikeMan MikeMan is offline
Banned
Send a message via ICQ to MikeMan
Usually a hesitation when you stamp on it is due to the fuel mix being off. Could be a number of things causing this though:
MAF (Mass Air Flow) sensor
O2 (Oxygen) sensors
FPR (Fuel Pressure Regulator)
Fuel dampener
either fuel line (supply or return) being clogged or pinched or something.
ECCS
Tune up would cost you around $200-$400 here (Australia) so expect to pay about $150-$300 USD.
Have you remembered to change the timing belt when you got it?
-Mike
Old 11-11-2004, 02:13 AM
k3smostwanted's Avatar
k3smostwanted k3smostwanted is offline
Z Cars Fanatic
Send a message via AIM to k3smostwanted
um...i have that same problem with my 1990 auto. i have done a full tune-up and it is still there. mine is more of a quick hesitation like it bogging down for a split second. if you find it tell me, i just came to the conclusion that the auto transmission has a no slip feature or something. who knows???
ZedEx Crew Member #4
Old 11-11-2004, 06:14 PM
Thanks for the input guys.. I will keep you posted, going in the shop on monday... I now realize the AC wont turn all the way off???? Any insight??
Old 11-11-2004, 09:25 PM
Hodo Hodo is offline
The vents will continue to blow if your car is moving, it will be kinda cool air but its not because the AC wont turn off its becuase the vents are still venting. Some manufactures leave this in the car for safty reasons.
Old 11-11-2004, 10:02 PM
No, the ac comp. wont turn off. Even when the fan is off.
Old 11-11-2004, 10:11 PM
Z Cars Fanatic
hmm...sounds like its in the switch.
Old 11-12-2004, 03:33 PM
yea it sounds like the compresser switch is shot.... may want to also check your R134a Charge too. It could also be low, if not gone.
