Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '91 - '96
Old 11-10-2004, 08:58 PM
rclough rclough is offline
1996 Jetta Rough Idle / Stalling
I have a 1996 Jetta with 160K miles. The car has run perfectly for a long time. Over the weekend I replaced the spark plugs, wires, distributor cap and rotor. The car runs must stronger now however when I come to a stop the idle will vary between 400-800rpm and many times will stall. The car is a manual.
Any ideas on what may have gone wrong? Mileage is up about 2 mpg after weekend work (Was 36 on highway now at 38) but rough idle is a real problem.
No engine lite issues.
Old 11-11-2004, 07:46 AM
raymond888uk raymond888uk is offline
soulution
i had the same problem yesterday and took it to garrage and finally it was the throtel cable needed tighting it was because the engine was running to slow when stopped reply if this fixed your problem pleas [email protected]
Old 11-11-2004, 03:00 PM
boschmann boschmann is offline
Re: 1996 Jetta Rough Idle / Stalling
Rclough has a fuel injected car. Regardless whether it's FI or carb, adjusting the throttle cable to make up for low idle is wrong. First make sure you didn't break any vacuum hose while doing your work. It might be best to try cleaning the throttle body/valve. It's easy to do it on the car. Remove the air intake tube from the throttle valve & open it up & spray with throttle body cleaner. Use a toothbrush & scrub then clean out a few more times. The car will be flooded when you finish so it might take a few seconds of cranking to start.
