`89 cherokee code scanner
please recomend me a code scanner for my 89 cherokee laredo, i tried the on off on off on off procedure without success
if someone knows one cheaper i will apreciate |
Re: `89 cherokee code scanner
Check out JC Whitney- they have a cheap one that covers that year
Im18, Go to Autozone and get Haynes repair manual $14.99, it tells you how to check your codes by crossing wires in your computer hook up terminal under the hood and its probably going to be cheaper than a code scanner.
I also have an 89 xj that I can not get codes out of & the Haynes manual for the 89 Cherokee does not seem to help. Am I missing something? Any help would be greatly appreciated.
What exactly is the problem?
From AutoZone: "Entering the self-diagnostic system on models prior to 1991 requires the use of a special adapter that connects with the Diagnostic Readout Box II (DRB-II). These systems require the adapter because all of the system diagnosis is done Off-Board instead of On-Board like most vehicles. The adapter, which is a computer module itself, measures signals at the diagnostic connector and converts the signals into a form which the DRB-II can use to perform tests. The MIL or a scan tool can be used to read codes." |
Anyway, you asked, ANY help whatsoever to this newbie would be greatly appreciated. Thanks again
do you know the brand and part number of the adapter and the code reader?,
my jeep is working right now but i fill like it loose the power, i made the maintenance periodically but still the same, a few months ago suddenly didnt start, i check everything and i only found a loose wire in the oxigen sensor, i connected and it start again , so i went to the shop and they told me that the sensor isnt the problem, but they cant find any other problem, and i paid by the diagnosis, thats why i want a code reader if possible |
i also have the haynes manual, i went to autozone and pepboys and they try to sell me a digital voltage display thats plugs into the ciggarrete hole and came with a jeep codes book, but the instructions are to use the on-off... secuence
As far as I know ,the older XJs don't store codes.It doesn't have a check engine light.It has a maintenance light but that is controlled by a mechanical timer.The only way I know of to check for faults is with a DRB 2.It runs through a sequence of tests and then it will give you faults.As far as aftermarket testers I don't know of anysince I am a tech at a dealer,we always used the DRB 2
