Old 11-10-2004, 07:28 PM
BlackEclipse97 BlackEclipse97 is offline
Banned
Send a message via AIM to BlackEclipse97
car wont start? ignition??
i have searched and i saw a similar problem and i tried and checked what they said to do (bad battery connection or dirty posts) and the connection was fine and the posts are clean
ok tonight i was leaving after having dinner with my mom and when i got in my car and turned the key (clutch was in) all i heard was a click (i still had power and everything) so i waited for a little bit and tried again (b/c it has done this once before and i just waited for a little bit and it started) so finally after like 5-10 mins, it starts up what could this be?
Old 11-11-2004, 11:03 AM
Banned
Re: car wont start? ignition??
any one know????
Old 11-11-2004, 11:50 AM
joemathews's Avatar
joemathews joemathews is offline
Are you positive your battery is charged enough? If you hear anything happen when you turn the key, then your ignition switch and fuse should be working (if any lights come on in your dash, etc.)
Could be a wire grounding out somewhere...
1996 Eagle Talon
Old 11-11-2004, 03:51 PM
Banned
you can turn on the lights, radio, and gauges but the car just does one click when you turn the key to start it. it only does this problem some times though
Old 11-12-2004, 10:56 AM
97GSTspyder's Avatar
97GSTspyder 97GSTspyder is offline
Send a message via AIM to 97GSTspyder
hmmm...i have this problem sometimes but my problem is my ignition switch...when i turn the key to 'on' my lights and everything work, except for the power windows...i have to reach under the dash and jiggle around the ignition switch and i kind of have to stick it to a certain place in order my my car to start...you can try doing that...
Old 11-12-2004, 12:56 PM
Banned
where is the ignition switch under the dash
Old 11-12-2004, 01:03 PM
normally to see it, you have to rip off the lower part of the dash under the steering wheel and you take off the column cover. it's located on the left. it plugs into a connector. i think mine has a lose connection or something because like i said, sometimes i'll be driving and my car will just die out and i have to reach way under and up in there to jiggle it and then suddenly everything comes back alive. right now it must be in the perfect spot because my car hasn't died in about a month or so...
Old 11-12-2004, 01:07 PM
Banned
my car doesnt die though it just doesnt start sometimes (twice so far in a months time)
Old 11-12-2004, 03:11 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
check the wires on ur starter and maybe the starter itself. sometimes if you take something and tap on the starter it'll start up. but i'd still check the starter.
95 Talon TSI AWD
97 Eclipse GST
Old 11-12-2004, 03:49 PM
Harder Faster's Avatar
Harder Faster Harder Faster is offline
Sounds like it could be your starter.
\Sleep"er\, n. 1. One who sleeps; a slumberer
Old 11-12-2004, 04:23 PM
Banned
yeah lol i did that with our old lawn mower when it would turn over (taped on the starter)
Old 11-12-2004, 04:29 PM
joemathews's Avatar
Re: Re: car wont start? ignition??
Do the other electrical items power off when you try to start the car?
1996 Eagle Talon
Old 11-12-2004, 08:05 PM
Banned
i dont think they do? ill check next time it does it (hopefully it wont lol)
Old 11-13-2004, 02:26 PM
9neon5 9neon5 is offline
i think you have a dead spot in your starter.
Check out the N3ON
http://www.cardomain.com/id/9neon5
Old 11-14-2004, 10:22 PM
grandpos grandpos is offline
Send a message via MSN to grandpos
I would check the wiring to the starter, eve tho the wires are connected there could be corrosion inside the covering. I have had this problem before ( although not with DSM) , and the wires felt fine, but they were very corroded, put a new conncetor on, and no problems since.
