Old 11-10-2004, 07:19 PM
dmr979s dmr979s is offline
speed limiter
does anybody know of any way to disable the speed limiter on a gtp w/o buying a reprogramed PCM?
Old 11-10-2004, 07:23 PM
stlwagon stlwagon is offline
Re: speed limiter
You'll need a new PCM to remove the speed limiter.
Old 11-10-2004, 07:33 PM
that sucks - do you know what speed they shut down at - ive been reading the forums and seen everything from 108-128!
Old 11-10-2004, 07:37 PM
kustomkid54's Avatar
kustomkid54 kustomkid54 is offline
Re: speed limiter
And reprogramed ones are set at 255!!!
Old 11-10-2004, 07:41 PM
Re: speed limiter
I believe OEM is 126 mph due to the tire rating.
Old 11-10-2004, 07:52 PM
Re: speed limiter
I know they take the speed limiter out. The computer has to have a number to set at. So, it is set at 255.
And speed rating is 149; http://www.discounttiredirect.com/di...peedRating.jsp
Old 11-11-2004, 02:38 PM
theblurr87 theblurr87 is offline
Send a message via AIM to theblurr87
Re: Re: speed limiter
it just dawned on me why its 255. its a 8bit variable. 2^8 is 256. sorry, i know none of you care. damn programming courses oh well any high and it blows up!
'99 SE (l36) 125k mi.
FWI | ZZP HVTB St. 1 | WP UD Pulley | 3" DP/HF Cat/U-bend Del.
Old 11-11-2004, 07:26 PM
Re: Re: Re: speed limiter
I don't care how it works out. All I know is it helps your car move, FASTER.
Also found out that they have some tires rated at 189 MPH.
