Go Back   Automotive Forums Car Chat > Jeep > General Discussion
Old 11-10-2004, 06:46 PM
T-$$ T-$$ is offline
CJ-7 replacement engines
anyone got good suggestions on a good crate engine to replace the spanked one in my 84 CJ-7? (straight 6)
Not too much and good quality
Old 11-13-2004, 06:21 AM
76 maverick's Avatar
76 maverick 76 maverick is offline
Whats wrong with the I6 , is it a 258 or a 4.0 ?
"I live in my own mind , an`t nothing but a good time , no rain just the sunshine out here in my own mind"
Old 11-13-2004, 06:12 PM
Re: CJ-7 replacement engines
nothing wrong w/ my 258 sept its old and beat, just want a equal replacement.
Old 11-13-2004, 09:29 PM
You might be best off with a re-ring kit depending on how bad it is. Does it burn oil ?
Old 11-14-2004, 09:31 AM
if i park it on a hill and leave it in gear, it will turn over the engine quite easily. if i leave the pvc valve where it should be it pushes oil out the rear main and a few other areas. but no, it really doesnt seem to burn the oil, just leaks it with pvc installed.
I dont loose coolant anywhere and it will hold pressure no prob.
i had the oil pan off it and the rod bearing are pretty beat too.
the more that i have been thinkijng about it the more i realize that i should tear it down and give er a look first.
Old 11-14-2004, 01:23 PM
I don`t know of any "crate" 258s but you should be able to get a rebuilt one through a parts store. If I were you I`d check at some machine shops to see how much they would charge to rebuilt it for ya.
